Old 07-08-2010, 08:34 AM
asteriksi asteriksi is offline
lost power while driving
it happens to lose power when I switch on the car air conditioner (the car engine stopped at all the moment I press the brake pedal). same is when I am going uphill, I cant accelerate even if I press the gas pedal at maximum.
I have a Golf, '96.
I would like to know where to start diagnosing the problem.
thank you
Old 07-08-2010, 01:57 PM
shorod's Avatar
shorod shorod is offline
SHO No Mo
Re: lost power while driving
I'd suggest you start by confirming there is no vacuum leak, then perform a tune up (including fuel and air filters). If that doesn't fix the issue, check fuel pressure and make sure the idle air control system is functioning properly.
-Rod
Old 07-16-2010, 10:45 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
There is a relay and/or a vacuum-actuated valve that is supposed to increase the idle speed of the engine when you turn the A/C on. If they are not working, then the A/C load may be too much when you are at a stop. Check the relay, vacuum lines, and wiring to/from these parts.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
