Old 05-12-2003, 02:07 PM
SFTB SFTB is offline
Question How ro properly put CF decals on complicated geometries
Could someone post a step by step way to apply CF decal on an irregular surface . With pics if possible... how to make the initial template?!?
RallyRaider you seem pretty good at this buy the way you built your Peugeot 206... Show me how good your decal skills are!!! I was really impressed buy the mirors and tha gas tank.
Thanks
SFTB
Old 05-12-2003, 02:32 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
id like to know too.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 05-12-2003, 02:36 PM
bigfrit's Avatar
bigfrit bigfrit is offline
with CF decals, there is no miracle solution.
All you might need is a lot of patience, a decal softener to bend nicely around curves and an earbud or something not-sharp to put them into place.
You might want to use a hair drier if appling decals without decal setter (microset) and decal softener (microsol) or similar products.
Should be actualy a post about this (or several)
Olivier
Old 05-12-2003, 02:51 PM
935k3's Avatar
935k3 935k3 is offline
To make a pattern simply use masking tape to cover the part then go around the edge with a pencil to make the outline. Then take the tape off and lay it on cardboard or plastic to make the pattern. Then trace the pattern on to decal and cut it out.
Old 05-12-2003, 03:14 PM
daggerlee's Avatar
Decals should also be a little larger than what you cut out so they will fit properly on the model.
Dan
Old 05-12-2003, 03:35 PM
DavidG DavidG is offline
me three
how the heck you guys get those decals in those places, like the intakes.
do you have pics, and what to use???
Old 05-12-2003, 11:12 PM
SupercarFreak's Avatar
SupercarFreak SupercarFreak is offline
I just make sure I cut the decal big enough, you don't want to make it too small otherwise you will have to use more than one decal and you will see the overlap
i also use a decal setting solution, it works wonders
Old 05-13-2003, 08:29 AM
COZMO6476's Avatar
COZMO6476 COZMO6476 is offline
how do you get the extra off?
Old 05-13-2003, 08:49 AM
marci-blitz marci-blitz is offline
check this link:
http://www.msmodels.co.uk/carbonhelp.htm
Old 05-13-2003, 09:32 AM
lumpulus lumpulus is offline
Banned
I use a brand new no. 11 Exacto blade when I decal CF. Just lightly running the blade over the decal where the border is gets the extra off for me. Do not wait for it to dry to do this!
Old 05-13-2003, 12:10 PM
Mean_B16's Avatar
Mean_B16 Mean_B16 is offline
Microsol is the only way to make it look real.
Old 05-13-2003, 12:20 PM
freakray freakray is offline
AF Modelrater
Originally posted by SupercarFreak
Like paint, carbon fiber decals hide nothing, it is best to fill any sink marks or ejector pin marks before applying the decals. Failing to fill these actually makes them stand out more one the decal is applied.
AF User Guidelines
Old 05-13-2003, 02:30 PM
i noticed this is my first model
i will try to remove all molding lines and stuff on the body
Old 05-13-2003, 07:41 PM
so let me guess this right, so i dont mess it up
you disolve the microsol in the warm water, put the decal in, until is ready to move to the part, make sure there are no bubbles, taking them off with a qtip, and a small brush to keep the moisture, after all the bubbles are out, use a hair dryer to let it dry.
so is that correct???
Old 05-13-2003, 07:52 PM
AF Modelrater
You do what?
You place the decal in the warm water until it will slide off the backing, once you have the decal in place on the part, then you apply the microsol to soften the decal and help it conform to the surface.
once microsol is applied, don't touch the decal until it is dry completely, even if it shows small bubbles don't touch.
Once it is dry, pop the small bubbles with a sharp blade or pin and gently push the air out with a wet Q-Tip, then apply more microsol and leave it to allow the microsol to work.
No matter how tempting, don't touch the decals when they are wet with microsol, you will only mess them up if you touch them.
Ray
AF User Guidelines
