Old 05-12-2003, 12:00 PM
rosman4u rosman4u is offline
startup problems with b16a swap
Well I finished my swap, b16a into a 88 civic dx, wire harness conversion done, all set to go, try and startup the motor and it cranks but I get no spark, ??? anyone run into this with there swap, I checked everything but no spark, bad distributor maybe? help please.
Old 05-12-2003, 12:05 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
Check your ignition coil, cap and rotor. I would replace them if u haven't done that yet.
Old 05-12-2003, 12:10 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
ive heard alot of the dizzy's dont work right, so id check into that first.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-12-2003, 12:53 PM
hmm..I did change the cap & rotor still to no avail, if I order a new distributor what should I order from? 95 del sol vtec? or any 88 civic & up will do? I was told a 95 del sol dohc vtec cap & rotor should work, well it didn't, what did work was a 90 civic si cap & rotor.
Old 05-12-2003, 02:52 PM
redmanjd redmanjd is offline
i had the same prob it was my distrib
95 b18b
new crank, eagle rods, je 10.5 : 1 pistons, 8lb flywheel, stage 3 act clutch, billet aluminium and urathane mounts, balanced rotating mass, 14.3 @ 93mph
New additions, teo4h turbo, ssautochrome turbo manifold, custom piping, turboxs bov, dsm 450cc injectors, greddy e-manage fuel controller 13.07 @ 107 untuned
Old 05-12-2003, 03:17 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Try changing the coil before you go shopping for another distributor. They are fiendishly expensive.
Besides, the coil probably costs less than $50, and if that's not the problem, you can always take it back and get a refund.
Flunky
PS-I once had the same problem you've got now, and a new coil got it to make spark again. Take the one out of your distributor and take it with you when you go to purchase a new one.
PPS-The other culprit that can cause lack of spark is the ignitor.
Old 05-12-2003, 03:18 PM
crxlvr's Avatar
id say the dizzy out of a 94 del sol vtec should work.
1991 Honda CRX
2003 Honda Accord
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-12-2003, 03:35 PM
mellowboy's Avatar
It'll work but remember but those are obd1 and obd2 distributors u guys are talkin about. U can use the 90-91 integra distributor but u have to break off the third leg. I'd say replace the coil to see if thats the problem.
Old 05-12-2003, 03:37 PM
mellowboy's Avatar
Always use distributor parts from a non obd.
Old 05-12-2003, 09:39 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
make sure all your grounds are tight first. especially check the one that bolts to the thermostat, everyone forgets it. if that doesnt solve your spark problem, check everything in your distributor. look in the haynes or the helms manual for resistance specs for the primary and secondary windings for the coil, and the igniter resistance specs. if anything isnt right, then replace the part.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
