Old 05-12-2003, 06:28 AM
djextasis djextasis is offline
Send a message via ICQ to djextasis Send a message via AIM to djextasis
Angry Alternator Belt Keeps Snapping!
I just bought a '95 Eagle Talon ESI for $3000. I had a mechanic check it out, and he said that in the shape it's in, it's definately worth more than that, so get it. The guy I was buying it from is moving accross the country, and said that he needed the money, so if I didn't buy it he was going to part it out and junk the rest. Anyways, the 2nd day that I had the car, the alternator belt snapped. It looked a little tender, and the power steering belt was getting there, so I had both of them replaced. About an hour after that, they both snapped. So, I had the alternator checked, and replaced, then new belts put on, and the alternator belt just snapped again - I'm stumped! The 2nd 2 times they broke, I was spinning the tires, at like 6000 RPM. My mechanic can't see anything wrong with the car, so my question is, is this common, and if so, how do I fix it? Any help would be much appreciated.
Old 05-18-2003, 08:46 AM
D2daT2daM D2daT2daM is offline
it is fixable by gettin another car
Old 05-22-2003, 11:08 AM
turboawdgsx turboawdgsx is offline
Is it the right size belt? How tight are you tightening it? Also is your lower crank pulley separating? If so that would cause it to snap. Check for any sharp edges around your timing belt cover. When you apply tension to the belt, there should only be about 1/8-1/4" of deflection. Good luck, w/b with any more questions.
Rob
"Got car lenghts?" or "You can turbo anything but can't make stupid people smart, something wrong with this picture?"
Old 11-09-2004, 06:46 PM
mstngeater mstngeater is offline
Send a message via Yahoo to mstngeater
According to another thread, the crank pulley has a piece of rubber between the two pulleys that goes bad and creates a wobbling. This pulley needs to be replaced. Hope this helps you as it has helped me.
Old 11-09-2004, 09:50 PM
kjewer1 kjewer1 is offline
AF - Advisor
Re: Alternator Belt Keeps Snapping!
Do the NT motors also use the crank pulley with the shyte rubber middle? I assumed only the 4g63s had that problem with those falling apart. But that could do it. Over tigtening it, pulleys misaligned, etc.
Kevin Jewer
RWD Talon - 7.92 at 180
Mightymax - 10.7 at 125
