Old 05-12-2003, 04:36 AM
grumpee grumpee is offline
Exhaust Problem Help!
WIERD PROBLEM. My exhaust sounded fine until today; where there is a wierd STUTTERING exhaust note coming from it. I would rev the car to 2.5 rpm, and the needle would sort of stay there with the stuttering exhaust note getting louder. Then, it would break through the 2.5 barrier with the rpm going up and the exhaust would sound fine from there on. But everytime i change gear, the barrier and the stuttering would be there again. Is this BACK PRESSURE?? What could be wrong??? I lose power when there is the stutter and could hardly climb up the slope to my house. PLease HELP!
P.S: What exhaust system is recommended for power gains and a nice, deep but NOT LOUD TONE. THANKS ALL!
Drive fast, die faster, so what? I Like....
Old 05-12-2003, 02:40 PM
SiRII's Avatar
SiRII SiRII is offline
sounds like a timing problem
Old 05-12-2003, 11:12 PM
Timing Problem? WHat is that?
Timing problem? WHat does that mean? Timing belt? Cam gears?
Old 05-16-2003, 01:10 AM
b16a3sol b16a3sol is offline
check all your plugs and make sure the ignition system is up to spec. if that checks out, check the fuel system and make sure its all in spec also. make sure that all your cylinders are performing properly, as one of them might not be up to par with the others, killing performance until there is enough momentum in the motor to keep itself running close to normal.
Originally posted by honda720
i would never drive like that thats the pussy way to drive stick
