Old 05-12-2003, 12:58 AM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Safe in water??
I started my R32 GTR's engine today and after cleaning all the mold lines off I decided it would be better if I glued the two engine halves together using Testors CA glue. I still need to scrub the engine in soapy water to remove dust and oils, will this affect the CA glue?
Old 05-12-2003, 02:08 AM
008's Avatar
008 008 is offline
Re: Safe in water??
Only acetone can dissolve that stuff, unless you break it off.
Old 05-12-2003, 03:29 AM
BOOSTD's Avatar
Ok thanks, I have also added a bit of Tamiya Basic putty to the model will this be affected by water??
Old 05-12-2003, 04:46 AM
theoldboy theoldboy is offline
not unless you use a wire brush
Old 05-12-2003, 08:18 AM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
ive had some bad experiences with putty and water. it seems like the water gets into little pores and weakens the putty.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
