ac problem
i have a 98 chevy s-10,i had no ac and finally checked it out,turned on the ac in the cab but nothing but hot air,checked the compresser and the clutch was not turning,jumped out the compresser from the battery and it worked great,plenty of cold air,checked the pressure,it was 38 pounds with ac on,100 psi when off.With the compresser not coming on with the ac control in the cab could this be a pressure switch or electrical issue, just about ready to throw a toggle switch on it and control the compresser manually,any help with this would be appreciated ,THANKS
Re: ac problem
Have you checked fuses and relays?
Re: ac problem
i checked the fuse and relay and both were fine
Re: ac problem
Often it's the pressure cycling switch (the switch on the accumulator) that's bad. I just replaced mine today, as a matter of fact.
1993 Olds Bravada 4.3L CPI 1999 GMC Safari SLE AWD 2002 Chevy Astro LT AWD |
Re: ac problem
I recently had to replace mine as well.
Re: ac problem
how tough is it to change that switch and what would be the cost roughly to buy one,and thanks for the info
Re: ac problem
It's right out in the open. Unclip the wiring harness, unscrew the switch, screw on the new switch, reconnect the wiring harness. The switch is on a schrader valve so no refrigerant leaks during the swap.
Cost about $20 at advance auto for the AC Delco part (recommended).
Re: ac problem
thanks for the info,trying it out today get back to you and again thanks you probably saved me a couple of hundred bucks
