Old 05-11-2003, 01:59 PM
shieldwulf's Avatar
shieldwulf shieldwulf is offline
Painting taillights
I have searched and read the threads on painting tailights, and also painting silver or metal foil of the body recesses where the lights are on.
Well, I brush painted the recess of the car body (where the lights are supposed to be attached) using Tamiya Chrome Silver and painted the BACK of the tailight parts using Tamiya Clear Red and Clear Orange.
However, on painting the clear colours, they got worse looking on each layer of brush painting. In other words, they looked ugly especially when dried.
Am I missing something? Or is it mandatory to airbrush for the best effect?
Any advice is appreciated.
Old 05-11-2003, 02:07 PM
daggerlee's Avatar
On which side did they look ugly, the painted side or the clear side? And how are they 'ugly'?
In my experience, shaking Tamiya clear paints is not recommended since air bubbles form in them, so that couild be a cause ; stir, don't shake. Also, you may not be mixing it well enough, causing uneven coatage.
Dan
Old 05-11-2003, 02:14 PM
shieldwulf's Avatar
They don't look good from the "outside". "ugly" as in uneven paint coats, somewhat like translucent little "patches" of varying shades of the same colour.
And yes, one possible reason could be I may have over-stirred the paint.
When I paint on the second layer after the first layer is dried(day before) it seemed to be affecting the first layer too.
Old 05-11-2003, 02:22 PM
Marco_Wrc Marco_Wrc is offline
Rally Fan
I painted the lights (clear parts) inside and outside (didn't know what the exact procedure was, so I just tried it) and I must say, it looks very good.
daggerlee's Avatar
That should be normal. Keep on applying coats until an even color has been achieved. Should take at least two or three coats, possibly more.
I'm sorry if you misunderstood me but I said it might because your paint was understirred, not overstirred. You can't overstir paint.
Dan
Old 05-11-2003, 03:45 PM
irupp33's Avatar
irupp33 irupp33 is offline
Send a message via AIM to irupp33
i think best results are achieved with an airbrush.
1991 Eclipse GS-T
Exterior: stock
Interior: Boost and A/F gauge, TV/DVD player, thats about it.
Motor: supra side mount, hard pipes, greddy type s, greddy profec b b/c, nology hotwires, 3 in. turbo back exhaust.
Wheels and tires: stock shitty fan rims with stock tires (no grip what so ever)
Old 05-11-2003, 08:02 PM
primera man's Avatar
"P-Man"
Do thin coats and allow plenty of drying time.
Sounds like you maybe dragging the bottom layer off with the next coat.
View All My Models Here.
Old 05-12-2003, 03:31 AM
chaos's Avatar
chaos chaos is offline
AF Premium User
Ditto - drying time is the key. Let the applied coat dry well before applying another coat. Painting the head/tail lights is one of the 1st things I now do when I put together a kit.
Old 05-12-2003, 12:03 PM
shieldwulf's Avatar
paint thickness
Do I paint thin coats using the paints straight & stirred from the bottle or do I thin some first with Tamiya Acrylic Thinner prior to brushing the thin coats?
Old 05-12-2003, 02:31 PM
2000-redrider 2000-redrider is offline
You can thin the paint a bit with water. The coats will be thinner, so you'll need to put on more coats. But as stated before, make sure you give it plenty of time to dry.
Old 05-12-2003, 11:40 PM
BOOSTD's Avatar
BOOSTD BOOSTD is offline
Do you get best results by painting the back of the model (where the lights go) silver and then painting the inside of the lense with the clear colours, or is there a better way to do it?
Old 05-13-2003, 12:01 AM
christofurr's Avatar
christofurr christofurr is offline
That's what I've done in the past, and if you haven't got a steady hand, some of the silver paint can go outside the light recess in the body, which doesn't look pretty.
This here looks like a much better way of doing things...
http://www.tamiya.com/english/howto/car1/tip2.htm
Old 05-13-2003, 12:11 AM
BOOSTD's Avatar
Wow that link is great. Thanks for that
