Old 05-11-2003, 01:37 PM
fiercecivic's Avatar
fiercecivic fiercecivic is offline
Send a message via AIM to fiercecivic Send a message via MSN to fiercecivic
doors leaking
Hey does anyone have the problem of water leaking down their windows and into ur door? Cause it rained pretty good last night and when i got in the car there was water coming out of my door speaker grills, although my speakers were barely wet I sprayed water down the window and know that thats were its coming from, anyone know this problem and got a fix for it???
Old 05-11-2003, 01:47 PM
crxlvr's Avatar
crxlvr crxlvr is offline
Slowest Automatic Civic
Send a message via AIM to crxlvr
ive had the same problem for years on my crx, but it never affected my speakers either, its prolly some worn out window striping.
Stable Of Cars I have Owned:
1991 Honda CRX
1990 Oldsmobile Cutlass Supreme
2003 Honda Accord
1998 Chrysler Concorde
2007 Honda Civic
1997 Toyota Camry
1995 Saturn SC2
1996 Ford Taurus
1991 GMC Sierra
2002 Daewoo Leganza
1999 Dodge Ram
2007 Honda CR-V
2003 BMW 325i
Old 05-11-2003, 02:13 PM
dirtydx dirtydx is offline
the water was running down into the backseat on mine. mine just had a crease in some weather stripping, which was an easy fix. u might have to put some silicone in there, last resort.
"I just threw away a lifetime of guilt-free sex and floor seats to every sporting event in Madison Square Garden. So, please, a little respect, for I am Costanza, Lord of the Idiots."
Old 05-11-2003, 04:17 PM
civickiller civickiller is offline
Send a message via AIM to civickiller
yeah i got water leaking in my drivers side window, because the rubber on the top of the window which the glass suppose to slide into, its all bent out of shape so the window doesnt slide in, it just hits it leaving it alittle open so water can get in
Team Lonely Drivers
Old 05-11-2003, 04:26 PM
ok thnx, at least its not gonna hurt the speakers, and it only leaks if it rains really hard
Old 05-11-2003, 04:53 PM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
In your case, I dont think this has anything to do with your leak, because your car doesnt have a sunroof. But heres my experience with leaks.
Most of my friends that have Si's have all been throught this at least once.
The 4 drain lines for the sunroof get clogged from time to time. The easiest way to tell if they are clogged, is to open your sunroof and dump water into each of the 4 corners of the sunroof track. The water should come out of each wheell well, respectively. If not, then check the lines. The two front lines run down throught the A-pillar down behind the fenders, and the rears run down beside the back of the car. The back ones are accessable just to the outside of you taillight access panels.
Old 05-11-2003, 10:09 PM
Dx18704 Dx18704 is offline
Send a message via AIM to Dx18704
civic killer i got that same damn problem
\m/ (-.-) \m/
Rock and Roll will never die
Old 05-13-2003, 05:19 PM
outofstep's Avatar
outofstep outofstep is offline
Send a message via AIM to outofstep
i leak from my passenger door near the mirror, and also from my rear view mirror if it rains hard hehe, some times ill go jump in and my seats are really wet
i belive its just the seals around the glass. should be able to pick up some kinda apoxy or something, or you could take all the seals off and reseal it :finger: but im much to lazy for that
90 civic:
JDM d15b
CAI
hp racing headers 4:2:1
custom 2 1/4 exhaust no cat
vafc2
skunk2 adj cam gear
B&M fpr
B&M fpg
tockico illumnia 5ways
eibach sportline
front & rear strut bars
CF SIR hood
Check out outofgames.net for your gaming needs!
