Old 05-11-2003, 12:03 PM
DDogg DDogg is offline
Help My Car's On Stands!!! (coilovers?)
I have my shock assemblies out of my car and dissasembled. I am installing tsudo coilovers on a stock strut. all on a 91 dx hatch. I have the new assembly together but the I have two bags of O-Rings(Two different thickneses but both about 2" in diameter.) The instruction sheet says nothing about them. ANYONE WHO HAS ANY EXPERIENCE WITH THIS PLEASE HELP, I HAVE TO GET TO WORK IN THE MORNING!!:o
Accel Wires and distributer
NGK Platinum Plugs
Tsudo coilovers
Tsudo Fireball Cat-back
Custom cold air intake
Kenwood 7" Monitor
Amp's, Speakers, etc.
Old 05-11-2003, 12:18 PM
lorunner lorunner is offline
i believe that the o-rings go on the shaft iof the strut so when you slide the threaded part of the coil over onto the strut it centers it and keeps it fron moving around. basically they take up the gap between the stut body and the threaded sleeve.
Old 05-11-2003, 12:54 PM
thanks, but do you know why i have two different size packs of 10. I have installed them and the car doesn't seem to be lowering when i adjust the sleave Do i need to cut the bump stop or dust cover?
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
Old 05-11-2003, 01:52 PM
91civicDXdude's Avatar
you have to adjust them a fair amount to have anything noticeable. If you want to have zero fender gap, adjust them all the way down... you will notice a difference, then adjust them up from there.
