Old 05-10-2003, 10:45 PM
DDogg DDogg is offline
Coilovers
Jus wondering if anyone can give me any pointers on installing my tsudo coilovers on a 91 hatch. Are there any secrets to cuttin down on the noise? Will I need to grind the shock or mount on the stock setup? Any help would be appreciated!
Accel Wires and distributer
NGK Platinum Plugs
Tsudo coilovers
Tsudo Fireball Cat-back
Custom cold air intake
Kenwood 7" Monitor
Amp's, Speakers, etc.
Old 05-10-2003, 11:11 PM
Please help!! Will I need a spring compressor tommorow?
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
Old 05-10-2003, 11:49 PM
91civicDXdude's Avatar
1. you DO NOT need a spring compressor for hondas.
2. remove the upper strut bolt from the shock tower (front & rear)
3. (rear) remove the lower control arm strut bolt.
3a. push the drum down and pull the strut out, remove the old spring and replace with coilover..installation is reverse of removal
4. (front) remove all brake line clips from the strut and remove the lower strut mounting bolt from the suspension fork.
repeat step 3a.
you are done. good luck.
Old 05-11-2003, 12:32 AM
Thanks man. No grinding and cuting?
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
Old 05-11-2003, 12:35 AM
oh yea, and how can i tell what to set em at. is it jus trial and error?
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
Old 05-11-2003, 01:10 AM
i set mine all the way down
Old 05-11-2003, 09:47 AM
91civichatch2571's Avatar
91civichatch2571 91civichatch2571 is offline
Send a message via AIM to 91civichatch2571
I didnt know it was as easy as 91civicDXdude said. I guess now ill be doing it myself when the time comes.
Old 05-12-2003, 12:27 AM
kutsuju racing kutsuju racing is offline
I WOULD NOT DO THAT IF YOU HAVE NEVER DONE IT BEFORE! I have always been told to use a spring compressor! Especially if you don't know what your doing. DDogg I know your not to far away from me if you need help you can drive out here and I can help you out. I was going to attempt to do it without a spring compressor on an accord and it sounded like the Body was cracking from the pressure!
They make spring compressors for a reason. But it's your car and stuff so if you decide to try it good luck.
Peter S.
www.kutsujuracing.com
Old 05-12-2003, 12:36 AM
XxLuckyLisaxX's Avatar
XxLuckyLisaxX XxLuckyLisaxX is offline
Send a message via AIM to XxLuckyLisaxX
if i can do it, and your not a total moron, you can change your springs as well without a compressor just be careful when the spring and strut stocks are out and your uncompressing them just be careful do what you got to do point it away from you and use your feet to withstand some of the pressure, i have tsudos as well there alright, good drop, put them all the way down it looks the best, if u want to see pic of how low my car is with them just ask
Keep it real, and share the knowledge.....
Say NO to Primer!!
Old 05-12-2003, 01:37 AM
YOU DONT NEED A SPRING COMPRESSOR FOR CIVICS. i will say it a million and 2 times. I've done about 3 spring/coilover installations. they are not even under enough pressure to spring downwards when you remove the top strut mounting bolt. I belive that at rest, they are pretty much extended all the way.
Do i need to explain the process again for those who doubt me?
Old 05-12-2003, 05:02 PM
IT'S DONE!! LOOKS GREAT. OH AND BY THE WAY......NO SPRING COMPRESSOR. (PUT EM IN A VICE AND SHOT EM IN A TRASH CAN
NGK Platinum Plugs
Tsudo coilovers
Kenwood 7" Monitor
