Old 05-10-2003, 09:51 PM
HoNdaGrl03 HoNdaGrl03 is offline
Send a message via AIM to HoNdaGrl03 Send a message via Yahoo to HoNdaGrl03
What brand and what WATT amp
In about a month I'm going to get an amp and subs for my car. I need a amp to run for my speakers.. I have Pionner 3-way 6 1/2 200W and Pioneer 3-way 9x9 220W. What would be the best amp to get to run for those and what Watt. Thanks:flash:
~Jennah B
_______________________
96 Honda Accord EX VTEC
:jump:
AEM CAI w/ Bypass/Accel Performance Wires/Clear Bumper Lights/Clear Corner Lights/TYC Clear/Chrome Altezza's/Pioneer 6400 Head Unit/Pioneer 3-way Speakers (6 1/2's and 6x9's)/Red Racing Pedals/Red neon lights/16" Icw Racing Wheels /618/205/50/16 Nankang Tires/Window Tint/Avital 2200 Alarm w/ Keyless Entry
:::Need help with what I can do now:::
Old 05-11-2003, 02:51 AM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
do you want to run all four off one amp or off 2 separate amps (one for front & one for rear speakers)? or do you just want a 4 channel amp and run all 4 off one amp (means extra wiring, but not much). also does your car have factory tweeters in it like mine does (up on the dash near the windsheild)? but if you can find a nice 4 channel amp with about 400-700 watts max should be able to handle all 4 speakers to the point of blowing them up with lots of pretty sparks, anything over 300 watts should be enough for those poineer's though, just be sure to check the rating per channel and make sure it does not exceed the max wattage for the speakers. a 300 watt amp should do you fine with 4 channels.. I dunno what your price range is so I can't really suggest any brands...
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-11-2003, 06:45 AM
Yeah I was originally just wanting to run all four on 1 amp, unless it would be better or cheaper, to run two, either way.. I'm looking to spend about 300 or less on an amp(s). The guy up at Best Buy said the Kenwood 4-channel 500watt amp would be the best to get and they run about $235. Oh and yes I have those factory tweeters in the dash.. I don't know how to get them out to change them. If I get an amp would it kill my tweeter? Thanks
~Jennah B
:jump:
Old 05-11-2003, 02:41 PM
well easiest way to protect those tweeters without ripping the dash out and changing them would be to buy a set of bass blockers, and put them in the line to the tweeters. Also that 500 watt 4 channel amp should do fine, just be sure you wire it correctly, and that your headunit has 4 channel outputs.. It should have them, but some head units only have the RCA's for the subwoofer. good luck.
Old 05-12-2003, 12:47 AM
GScivic7's Avatar
GScivic7 GScivic7 is offline
Send a message via AIM to GScivic7 Send a message via MSN to GScivic7
most cd players come with an all purpose preamp, meaning there isn't anything special about it. some cd players have a non-fading preamp for a sub amp and some have a preamp for front speakers that blocks low frequencies. for a 4 channel amp, if you only have one set of preamp outputs on the back of your cd player, get two Y plugs and that'll fix that. and I'm pretty sure that your Pioneer speakers right now are no where near 200+ watts. I'm pretty sure it's really about 50 watts RMS for the 6.5" and i'm not sure about the 9x9. Those are max numbers and you don't wanna go by those numbers or you'll blow your speakers to pieces when you turn it up. and about thoses bass blockers, you wanna run those inline on your positive wire
Empty Pockets Racing Member #1
