Go Back   Automotive Forums Car Chat > Cadillac > Seville
Old 05-10-2003, 09:01 PM
BluesPlayer83 BluesPlayer83 is offline
1986 Seville ... I have a ht 4100 v8 thats running hot
I need some advice .... Ive changed coolant ... ripped out the radiator and had it dipped in chemicals ... changed thermostats ... and have done other things and it is still running hot. The coolant temp is hanging around 230-240 after a good drive in warm weather. I have heard bad things about the ht 4100 v8 and I was wondering if this is a normal occurance.
Old 09-12-2003, 11:45 AM
h_m_c h_m_c is offline
Lightbulb Ht 4100
Have you had your radiator cap pressure tested??
Old 09-15-2003, 11:45 PM
91rs's Avatar
91rs 91rs is offline
could be the head gasket. I had a 4100 series engine in a 1986 Deville and oh man what a piece of s#@% !
Old 04-02-2005, 08:42 PM
b65pauls b65pauls is offline
Exclamation 86 overheat
Are electric fans running? I had to by-pass the fan sensor with remote wired toggle switches to make sure the fans were running. Did you do a compression test? Are you losing any coolant? Do you have a good thermostat and rad cap?
Old 04-19-2005, 10:07 PM
JustRainMan JustRainMan is offline
Re: 1986 Seville ... I have a ht 4100 v8 thats running hot
I had that problem with my 88 seville with a 4.5 motor and I noticed that the fan was turning real slow instead of fast. You could possibly have the same problem, you might want to check and see.I changed the sensor that controls the radiator fan.
