Old 05-10-2003, 08:18 PM
flyonthewall's Avatar
Car Mod guy
SAS Wings in detail - How to make...
Its come up on the board a few times and i've had several PM's about them so here's a build up of a wing which should answer a few Q's and help anyone having trouble with fitment and lining up parts etc.
To begin with parts are removed easily with a good pair of wire cutters, any stubs can be filed with needle files.
The fixings for the upper part of the struts require the tabs to be folded. Unfortunately coz of the design, a fold line could not be etched because of the bolt detail on this part - it was one or the other. So this makes it a little more fiddly but still not too much of a problem. If you hold the tab firmly in a pair of small nosed pliers, then press down the remaining part on a hard flat surface, you can easily bend the tab to 90 degrees as required.
When it comes to glueing parts together, superglue is the best method. It helps to get a better bond if the joing surfaces are roughed up with some sandpaper.
If you have took care with the bends and placement of parts so far, the struts will stand correctly if stood on end. Now's the time to fine tune the tabs if any of the bends are slightly out.
Onto the wings...
The wings ae best cut to length in a small mitre, this way you will get true cuts.
With the trickier double wing, it makes the task alot easier if you temporarily fix the two wings in relation to each other with tape. You can adjust the smaller wing to a setting u wish to replicate
Note the postion on the endplates...
When marking out the position for the struts start with a line for how far you want them postioned from the leading edge. Then measure in from the ends for each strut and do so again on a line at the rear so that they can be aligned straighly.
The finished wing should then look something like this...
Old 05-10-2003, 08:30 PM
Jonno's Avatar
Jonno Jonno is offline
Send a message via MSN to Jonno
Very nice tutorial Chris.
Do you include instructions like this in the kit?
-Holden Berlina Turbo, RB30ET.
-Mitsubishi Legnum VR4
Old 05-10-2003, 08:34 PM
daggerlee's Avatar
Well detailed like all of your tutorials
I'll be putting this one to use
Dan
Old 05-11-2003, 02:32 AM
integra818's Avatar
integra818 integra818 is offline
Send a message via AIM to integra818 Send a message via Yahoo to integra818
OMG, they're metal??? Unbelievable
They look very realistic, I've never really seen teh detail on these wings until now and I'm amazed by thier realistic look.
One questions though... do they work? If I were to push one of my models wearing one of those wings, would it stay on the ground? J/K
On a kinda off topic note: When I was building my Revell Toyota Atlantic car, I took the front nose piece and put it on the ground... turned on my VERY powerful compressor and blew air on it head on as if it was like air going to the front nose... THE THING WAS STICKING TO THE GROUND!!! It would come up, I tried to pull it and it wouldnt come off the ground unless I turned the compresor off.
Sorry for going off topic like that, I thought it might be interesting to hear that
Old 05-11-2003, 03:01 AM
Hiroboy's Avatar
Hiroboy Hiroboy is offline
www.hiroboy.com vendor
Great stuff, just what we all needed
Steve a.k.a. Hiroboy
Old 05-11-2003, 07:29 AM
primera man's Avatar
"P-Man"
Awesome stuff mate....you may want to put it in the FAQ
View All My Models Here.
Old 05-11-2003, 08:30 AM
exhaust smoke's Avatar
exhaust smoke exhaust smoke is offline
Phew! Glad I was doing it right!
Thanks for the reassurance. You may aswell use it as instructions for the kit.
Old 04-14-2004, 12:07 AM
builder's Avatar
builder builder is offline
Angry Re: SAS Wings in detail - How to make...
hi that wing you made was some thing else but what i would like to know is do tou have any tips for making a wing for a 1:12 scala 57 chevy belair im modifiing to look like a pro mod drag car anf need a wing
but i dont know how to make one do ypu have any tips for me
Old 04-14-2004, 12:13 AM
hondaaccordboy21's Avatar
hondaaccordboy21 hondaaccordboy21 is offline
im going to have to order some soon. I always say im going to but I put it off.
:IN PROGRESS:
Old 04-14-2004, 12:42 PM
builder's Avatar
Re: Re: SAS Wings in detail - How to make...
you have to order what soon. a sas wing kit ?
any one know where i can get the sas wing or any wing for a kit only for a 1:12 kit
Old 04-17-2004, 02:41 AM
builder's Avatar
Re: Re: Re: SAS Wings in detail - How to make...
no need to anwer jonno gave me an answer and i know now that i have to make one my self
Old 01-28-2005, 12:41 PM
tomtheman2's Avatar
tomtheman2 tomtheman2 is offline
Send a message via MSN to tomtheman2
Thanks Chris, thats realy usefull
Tom
Finshed : 350Z
In Progress : Supra
Old 12-16-2006, 07:29 AM
bigsupra's Avatar
bigsupra bigsupra is offline
Send a message via AIM to bigsupra Send a message via MSN to bigsupra
Great tut man. I wish they had instructions like this in the box.
