Go Back   Automotive Forums Car Chat > Honda > Integra
Old 05-10-2003, 06:59 AM
lordvektra's Avatar
lordvektra lordvektra is offline
Stroker kits
I love my integra but I want a little more bottom end. I found this
http://horsepowerfreaks.com/HTMLVersion/CROW_STRO.html
do any of you guys have a stroker kit or know how well they work.
B18 Series (A, B, C) Stroke 87mm Bore 95mm Total Displacement 2.26L $2,296.70 is the one im looking at, I haven’t found much on them, one guy said they may cause the top end to crap out. What do you guys think?
"Only two things are infinite, the universe and human stupidity, and I'm not sure about the former."
- Albert Einstein (1879-1955)
Old 05-11-2003, 02:54 PM
sameintheend01's Avatar
sameintheend01 sameintheend01 is offline
Send a message via AIM to sameintheend01
top end WOULD crap out. Acura intended the car to have low torque yet high horsepower with smaller displacement yet a high revving engine. you want more power, get high compression pistons. Prolly a lot cheaper and you won't alter the car's intended design.
Clear Corners
Front and Rear Strut Bars
Cold Air Intake with K&N filter
Iridium Spark Plugs
High Performance Plug Wires
High Flow Cat (unistalled)
Cool high/low beam lights
All around slotted and AEM pads
Old 05-11-2003, 03:17 PM
91civicDXdude's Avatar
torque is better to have at high rpms than low because you can take advantage of gearing. so say you have an integra that has 120ft/lb of torque @ 4,000 and another integra with 120ft/lb of torque @ 8,000, the one with torque at 8k will outpower the other..
Old 05-11-2003, 10:00 PM
yeah, but if you put a stroker kit on it, your torque might be at 4000 (which i agree is better) but your red line will be a lot lower (for the ske of argument at 5800). You're not getting gain by putting that kit in....
Clear Corners
Iridium Spark Plugs
Old 05-11-2003, 10:01 PM
god damn, you could stick a FAT turbo on an integra for that price and be a LOT faster.
Clear Corners
Iridium Spark Plugs
Old 05-12-2003, 09:32 AM
lordvektra's Avatar
cool, thats what I needed to know. also found out it would DESTORY the engine. might as well throw 15lbs of boost if I wanted to do that. Thanks for all the help
Old 05-12-2003, 02:49 PM
turbo your car!
Clear Corners
Iridium Spark Plugs
Old 05-14-2003, 02:55 PM
90gs's Avatar
90gs 90gs is offline
Send a message via ICQ to 90gs
why would it destroy the engine? hellof ppl stroke and bore their engine..
Old 05-14-2003, 05:23 PM
lordvektra's Avatar
they just said if you stroke it that much 1.8 to a 2.4 it wont last as long. Im not going to turbo the gs-r, too much trouble for not enough power.
Old 05-17-2003, 02:04 PM
pop in some high compressino pistons then
Clear Corners
Iridium Spark Plugs
Old 05-19-2003, 06:45 PM
york2600 york2600 is offline
Send a message via AIM to york2600
If you stroke it from 1.8 to 2.4 you will destroy your R/S ratio, but that's just because your adding 1/3 of the displacement to the car. You could stroke it to 1.9 or 2.0 and have a very nice setup. For the cost though it would probably be cheaper to get a B20 long block add pistons/rods and slap your GSR head and tranny on there. That's what I'm working on right now.
-Tim
94 Integra GSR Coupe
Mods: Professionally Built B20/VTEC: B18C1 head w/ pocket port, JE oversized pistons, Eagle Rods, block guard, ARP head studs, Skunk2 Intake Manifold, STR Throttle Body, AEM CAI, AEM Fuel Rail/Regulator, RC Engineering 280CC injectors, Denso Iridium Plugs, Magnacor Wires, DC Sports 4-2-1 SS Header, Greddy Evo Exhaust, ACT Stage 1 clutch W/ ACT flywheel, Apexi SAFC & Revspeed Meter, and many other toys.
