Old 05-10-2003, 01:11 AM
Problem_Si Problem_Si is offline
Send a message via AIM to Problem_Si
Jdm Big Brake Caliper/Rotor/Knuckle Swap
Hey guys,
Im new here, but I had a little info that might help some of you guys in your quest for Ef Supremecy.
As you know, The SiR had much bigger brakes than our dinky usdm setup, but good luck finding a set without selling your first born child. Well there is a better solution....
Seems, that the Jdm SiR and the Usdm 4door EX Civic share some of the same Honda OE part numbers. The only difference between them is the brake pads.
I've done the swap, and I am incredibly happy. My friend has the true JDM setup and side by side, you really cant tell the difference. Not a bad upgrade, and I can definetely tell the difference in braking. The only thing I had to do was adjust my Tie rods, because after I put the larger knuckles on, the car was "duck-footed".
Now before you go canabalizing every 4 door in sight, I believe its only the 90-91 EX 4door. I could be wrong, but the easiest way to tell is the wheels. These brakes are "integra sized", so naturally nothing smaller than a 14" wheel fits on them. Once you have the wheels off, you will see just how much bigger they are than the other Civic/Crx setups.
Happy Hunting!!
If any of you are interested....I may be coming across a set of these in the near future.
Old 05-10-2003, 04:47 AM
Setanta's Avatar
Setanta Setanta is offline
Send a message via ICQ to Setanta Send a message via AIM to Setanta Send a message via Yahoo to Setanta
I found that the JDM calipers only just clear 14s - if you have counterweights glued inside the wheel- be ready to have them ripped off - that's why I went to 15s. BTW - EG forks will fit too if you do the swap - that gives you a slightly larger in diameter strut while keeping the caps and springs the same
'99 PY DC2R
'85 BBS BMW E30
RIP '90 JDM EF9 Civic SiR
www.performanceforums.com
Old 05-10-2003, 04:55 AM
hmmm...
I might have to try that.
Since you're in Australia, you probably have the proper pads available to you. My friend had to dig and do all kind of research to find the matching honda number. Turns out that he has to use 92+ Prelude Brake pads on his 90 Ef9.
Go figure....
AlwaysMovin AlwaysMovin is offline
Aren't the SiR rotors 5 lug . I didn't think the EX brakes were 5 lug
If you are ever in the southwest desert and you see a dust storm coming your way, when I see you I'll wave hello.
My Home Page: Under Heavy Construction
Old 05-10-2003, 11:23 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
nope they are 4 lug and BTW 90-93 teg brakes are the same as SIR and 90-91 EX brakes i cuz i have them and parts wize they are the same too
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 05-10-2003, 12:40 PM
FourthGenHatch's Avatar
FourthGenHatch FourthGenHatch is offline
Send a message via AIM to FourthGenHatch
It's been known that EX Knuckles will give you like 10.3'' rotors or something.
http://www.fourthgenhatch.com
FOR SALE: Get this stuff out of my house!
-Stock hood (red) $30
-Stock Rear Spoiler (red) $30
-Stock mirrors $30/both
-Stock side front and rear side glass $30/piece
Old 05-10-2003, 12:42 PM
Stali08's Avatar
Stali08 Stali08 is offline
Send a message via AIM to Stali08 Send a message via Yahoo to Stali08
Nice Info bro.
Hey where at in PA are you from?
PeacE
Old 05-10-2003, 01:15 PM
The rotors and calipers may be similar, but the knuckles aren't. I think the integra has a different spline count for the outboard cv axle.
I do know that the part numbers are definetely different for the integra pieces.
And Im from The Valley Forge/King of Prussia Area
Old 05-10-2003, 02:05 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
part numbers are different, but not spline count. the difference between them is the thickness of the knuckles. the integra has a bit beefier knuckle setup. i have the integra ones, just finished restoring them, and have them next to some CRX Si ones for comparison, and there isnt any difference as far as location of mounting points for the tie rod and balljoints. basically its the offset of the caliper to accomodate the larger rotor, and a thicker knuckle. damn those integra ones are heavier....
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
