Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-07-2010, 12:46 AM
democrazy17 democrazy17 is offline
86 stang overheating
Hi there I have an 86 Mustang 6 cylinder that overheats on the highway, if I am only driving in the city no problem never goes over half but on highway it will redline, I put in a new 160 degree thermostat just to see no change any ideas?
Old 07-07-2010, 09:32 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 86 stang overheating
How's the coolant look? Is it full of rust? You should consider flushing it if you didn't when you changed the t-stat. If it's clean, than it may be a an air pocket in the top of the engine where the sensor is located, or a lack of flow through the radiator or other orifice.
Also check your water pump, it may not be working very efficiently anymore at the lower RPMs at highway speeds.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
