Go Back   Automotive Forums Car Chat > Nissan > Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35
Nissan Cefiro | Nissan Maxima | Infiniti I30 | Infiniti I35 Excellent platform and the good ol' VQ30DE and VQ35DE engines.
Old 05-09-2003, 10:07 PM
97wvmax 97wvmax is offline
Send a message via AIM to 97wvmax
Help Me!!!
my rear left brake sounds like somethin is stuck in it. ive gone to car wash and tried to blast it out and shit and it doesnt make noise when its wet, jus when it dries out. sounds kinda like some1 scratching a chalk board. any1 kno wat this is from? im gonna take off the wheel tomorrow and maybe grind the pad down a lil, any other suggestions?
Old 05-09-2003, 10:42 PM
thrasher thrasher is offline
Re: Help Me!!!
time for some new brake pads dude!!:bandit:
"Don't have sex man. It leads to kissing and pretty soon you have to start talking to them."
Steve Martin.
Old 05-10-2003, 12:54 PM
shouldnt be wearing like that, guys told me 2 front sets for every 1 back. but i will check that out! thnx
Old 05-11-2003, 04:44 AM
DiS's Avatar
DiS DiS is offline
Send a message via AIM to DiS
That screeching noise is the safety feature like on 3rd gen maximas, which lets you know that its time to change the rear brake pads. There is a metal piece that goes near the rear brake pads, and I think its the 1/2 lenght as the thickness of the brake pad. When brake pad wares off that metal piece makes the contact with your rotor (when you press brake)
97 Nissan Maxima GXE
Auto Trans
Red Injen Racing Division CAI with K&N FilterCharger, Zero1Racing Front Strut Bar
DaRk GrEeN/Beiege Interior
Cleared out taillights/Clear fronts/rewired blinkers and sidemarkers, upgraded grounding...Check my Pics out on my homepage
New purchase BRAND NEW '03 Mazda ProtegE 5-spd
_________________________________________________
Maximum Respect To MaxiManiacs and all Nissan 0wn3r$
Old 05-11-2003, 07:04 PM
its doing this when im NOT pressing the brake too. when braking it jus makes it worse
Old 05-11-2003, 07:57 PM
yup, definitely pads, no doubt about it
Steve Martin.
Old 05-11-2003, 08:33 PM
alright, thnx man. got the pads jus have to wait till wed for day off to work on them!
Old 05-12-2003, 10:59 AM
MaxPayne MaxPayne is offline
Send a message via AIM to MaxPayne
The Maxima's brakes are rear biased, meaning they will wear out faster than the fronts.
Old 05-12-2003, 08:46 PM
oh, god i hope i dont fuck the brakes up when i do this. i might be trading it in tho, so i jus stick them with it. altho im sure theyll jus cry over 20 bucks :smoka:
Old 05-20-2003, 03:32 AM
chillinMax chillinMax is offline
i hate changing my brake pads...its always a pain in the butt. When do i know i need new rotors? benefits of slotted rotors?
Drive Your Car like You Just Got Some.
Old 05-20-2003, 01:20 PM
DiS's Avatar
DiS DiS is offline
It takes my father to change all brake pads exactly 23 minutes in front of his house. I had my timer on As far as slotted rotors, they are better beacuse they release heat much faster, that is generated from braking, compared to stock rotors. do NOT get cross-drilled rotors unless you are getting oversized Brembo cross-drilled ones, because most of them tend to crack.
Auto Trans
Old 05-21-2003, 01:17 PM
i traded in the max for a truck last week, but i found out from friend at the dealership that the lil rubber peice that does over the caliper piston had tore and exposed the piston. thats all he told me, but i take it that caliper is prob locking up and thats wat the scraping noise was all the time CHILLEN, if u get new rotors dont get cross drilled, slotted should do ok tho, will reduce some of the heat from the pads
Old 05-24-2003, 03:40 PM
99maxse 99maxse is offline
Send a message via Yahoo to 99maxse
you are hitting your brake sensors that are on your pads to warn you that they are in need of a change. change the pads and you`ll be good. make sure you rotors aren`t to chewed up .... if they are you should have them cut.. pep boys or other parts store usually charge around 20-25 bucks per rotor.. good luck
Old 05-24-2003, 04:15 PM
97wvmax,
my brakes have been squeaky out the arse ever siince i got them. should i upgrade to oem pads? with slotted rotors, since it releases heat better, should it reduce the squeakiness?
its kinda embarasssing flossin' your ride w/your mods and system...stop at a red light and have the bunch of girls next to you cover their ears from the brakes
DOH!
Old 05-24-2003, 05:54 PM
my pads were not worn out by the way, it was something with the caliper, guy from dealership i kno called and told me a few days ago. chillen, mine did that too when i first got the max, sometimes it was cuz of dust and crap in the pads, try sprayin it out, or jus wait till ya pads wear down and change them, which u might wanna try urself, shops will charge out the ass for labor. dont worry bout the slotted rotors unless u were plannin on that, the heat shouldnt have anything to do with the squeak but will make ur braking a lot better, jus DO NOT GET DRILLED ROTORS the damn things will crack
