Go Back   Automotive Forums Car Chat > Lincoln > Continental
Old 07-06-2010, 06:36 PM
sherwood203 sherwood203 is offline
98 Continental inner tie rod replacment
I have a 98 Continental that needs the inner tie rods replaced. Does anyone have the repair procedure or has anyone done this before and can help me out. Shop wants $380 which seems way to high for something I was told is not to hard to do. Any help would be appreciated. Thanks
Old 07-10-2010, 11:47 PM
eddie8 eddie8 is offline
Re: 98 Continental inner tie rod replacment
Mark location of jam nut then remove. Screw inner tie from adjusting sleeve. Remove rubber bellows from steering rack, unscrew inner tie rod from rack. Screw on new tie rods, install new bellows and screw tie rod back into adjusting sleeve where it matches mark from old tie rod. Tighten jam nut. Get front alignment.
Old 07-13-2010, 09:32 PM
mn_1 mn_1 is offline
Don't you need a removal tool?
Old 07-14-2010, 09:12 AM
Yep, mn your right. Guess I just took that for granted.
