Old 05-09-2003, 11:50 AM
schlank schlank is offline
Unhappy Fuel pump problems over and over
I hope someone can help with this problem. I have an 87 camaro the engine is a V6 2.8 multiport fuel injection. The problem has to do with my fuel line. I have replaced my fuel pump and filter 3 times already. Every time it's the same thing. It works fine for many months then the car starts to die, then stutters on start then it finally dies all together, and is not restartable afterward. The mechanic's said it was getting sporadic pressure and that I would need to replace my fuel pump. Like I said it's happened three times, and Just last week the car started to have problems again. Now it's dead. I want to know if anyone has had the same problems, or if anyone knows if it could be something along the fuel line that could be stressing the pump to failure..
Thanks in advance.. you can email me at [email protected]
Old 05-09-2003, 03:33 PM
Gripenfelter's Avatar
Gripenfelter Gripenfelter is offline
Honorary Mod
Send a message via ICQ to Gripenfelter
Thats odd.
I would switch to a different brand of fuel pump.
Old 05-10-2003, 11:40 AM
bowtiebandit's Avatar
bowtiebandit bowtiebandit is offline
Send a message via AIM to bowtiebandit
Originally posted by Gripenfelter
Thats odd.
I agree, inspect the sending unit connections inside the tank and make sure the one at the top of the unit has not melted or turned black. You may not have a pump priblem but a sending unit problem, I see this ALOT!!!
Shop Foreman
Corvette Specialist
A.S.E. Master Technician
L1 Certified
A.S.E. Master Machinist
GM Certified Technician
Old 05-11-2003, 06:18 PM
reconmike reconmike is offline
replace the fuel pressure regulator, it might be over working the pump, even 2-5 psi over spec will kill a pump.
Old 06-04-2003, 06:13 PM
Murco's Avatar
Murco Murco is offline
Maximum Car Guy
Send a message via Yahoo to Murco
Thats odd.
That, and a different mechanic!
As stated above, check wires, replace both the sock and the pump along with the fuel filter. These items are relatively easy installs and only cost about $50 altogether. For another $25 you can get a pressure regulator (good call reconmike!) and eliminate any restrictions. Before installing, sit the pump in a pot of gas for 10 minutes so it can "prime" itself and NEVER let the tank get below 1/4 full. Inspect the tank and old sock too! Could be crud in the bottom of the tank.
Keep us posted!
My AF Classic Model Car Gallery
Old 09-26-2003, 01:20 PM
Spitfirebird Spitfirebird is offline
Fuel Pump Problems
Realize this post maybe OBE...but it may help other folks with problems.
The instructions that came with my fuel pump stated that the oil pressure sensor/sending unit can/will disable the fuel pump if it is not working properly. I think a sign of this would be wild fluctuations of oil pressure on your gauge. My problems were similar, and I think I had dirty contacts at one of the connectors under the hood.
2000 Tahoe LT Fuel Pump, Cats and Door Actuator ediesel_b13 Tahoe 0 05-14-2010 10:36 AM
1991 Regal Custom- Possible Fuel Pump Problem snickerkisses Regal 1 02-10-2010 10:08 PM
93 suburban fuel pump problem. robert1984 Suburban 2 12-15-2009 02:21 PM
bmw 325 fuel-pump testing and replacing dieter 3 Series 2 08-12-2009 02:46 PM
Fuel pump problem lmattiso Rodeo | Passport | MU 0 04-25-2009 02:08 PM
