Old 05-09-2003, 10:48 AM
DOWNRIGHTPINOY DOWNRIGHTPINOY is offline
Send a message via AIM to DOWNRIGHTPINOY Send a message via Yahoo to DOWNRIGHTPINOY
Boring The Engine
I HAVE SEEN SOMEONE BORE A D16 SOHC ENGINE TO 1.8...ANYONE KNOW THE ADVANTAGE OF PERFORMING THIS?
DJ koolaid
- I don't think anything is unrealistic if you believe you can do it. I think if you are determined enough and willing to pay the price, you can get it done.
Old 05-09-2003, 10:57 AM
Melt's Avatar
Melt Melt is offline
Send a message via AIM to Melt
you will have more displacement.
Not worth the money, just do an ls swap.
AF Bay Area Crew
97 Toyota T100 xcab 3.4l v6 5spd 2wd
Old 05-09-2003, 11:06 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
...usually they're not bored..they're stroked.
SOLD!
Old 05-09-2003, 11:41 AM
IM4U2NV81 IM4U2NV81 is offline
Send a message via AIM to IM4U2NV81
stroking gives more torque, boring gives more top end. Boring isn't for big increases, it is basically used in conjunction with stroking for more increases. However, if you do bore, definitely use at least a blockguard if you don't get sleeves.
91 hatch Si
D16Y8 SOHC VTEC from 96 civic
ghetto short ram intake, HP Racing header, Sprint 1.5" springs, 15" Rota Slipstreams, 195/50/R15 Dunlop Sport tires.
Old 05-09-2003, 11:43 AM
Re: Boring The Engine
that person must not have a personality!! HAHA!! Get it, he "bored" the engine. Damn, nevermind.
91 hatch Si
Old 05-09-2003, 12:08 PM
4-Door Flunky 4-Door Flunky is offline
AF Premium User
Bore and stroke are the two factors used to calculate displacement. If you increase the size of the cylinder or increase the length of the stroke (that's the distance the piston travels up and down) you will increase the displacement and the torque.
If the stroke gets too long, it puts stress on the sides of the cylinder walls, which is called 'sideloading'.
Stroke is like using a cheater pipe. The longer the cheater pipe, the more umph! you can exert. It's also like using a lever to move something. The longer the lever, the heavier the object you can move.
There's an advantage to having a short stroke, too. Once you've got a difficult nut loose, you take off the cheater pipe to decrease the stroke so you can get it off faster.
If you spin around in an office chair and pull in your legs, you can spin faster on the same energy. Same with ice skaters pulling in their arms when they are spinning superfast. They pull in the arms, and decrease the stroke, letting them wind wayy up!
Diesel engines have an incredibly long stroke. That's why they can pull a heavy load up a hill, but they don't wind up very high. Increase the stroke too much, and you can't wind up to the high RPMs.
'Stroking' is increasing the stroke. 'Destroking' is making it shorter.
Also, any time you increase the width of the bore of the length of the stroke, displacement goes up. Any time displacement goes up, torque goes up. That's why racers of V-8s say, "No REplacement for DISplacement."
Flunky
PS-Hope this isn't too 'boring'.
Old 05-09-2003, 12:15 PM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
They sell sleeves 84-85 mm for b16s that makes it 1.8 or gsrs that makes it 2.0. That'll increase the torque.
Old 05-09-2003, 01:03 PM
jNYCe5 jNYCe5 is offline
Send a message via AIM to jNYCe5
Originally posted by 4-Door Flunky
Bore and stroke are the two factors......
good info there flunky
*edit: didnt want to quote the whole thing
Julian
Old 05-09-2003, 01:06 PM
bdstbtch's Avatar
bdstbtch bdstbtch is offline
Send a message via AIM to bdstbtch Send a message via Yahoo to bdstbtch
You are SOOOO not funny....DORK! :silly2:
~ Cherylyn ~
Old 05-09-2003, 01:17 PM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
learn something new everydad so how much would something like that cost
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 05-09-2003, 01:57 PM
Flunky
that's all great and everything...but he asked about bore, not stroke. I actually happen to have a really long stroke, if you know what I mean!
91 hatch Si
Old 05-09-2003, 02:00 PM
yes, I understand that boring will increase torque. However, the torque gains from boring are very small in comparison to the torque gains from stroke. Boring is more beneficial at higher RPM's rather than low RPM's. But, yes, I know there will still be gains on the low end. Sounds like muck I know.
91 hatch Si
Old 05-09-2003, 02:01 PM
yeah, but who was grabbing who's....nevermind.
91 hatch Si
Old 05-09-2003, 02:06 PM
BLU CIVIC's Avatar
調整器
not us b/c u have an STD:silly2:
The name's Adrian
2011 CR-Z - Stock
Old 05-09-2003, 02:11 PM
D A M N ! !
91 hatch Si
Engine Rebuild abc234 Aveo 1 05-17-2009 06:38 PM
Boring out engine JJrenfro Engine, Transmission and Drivetrain 5 05-09-2005 05:29 PM
Boring out engine JJrenfro Engine, Transmission and Drivetrain 1 05-09-2005 12:14 AM
Boring the engine and Port Polishing. Xenostalgia Camaro Discussions 5 02-26-2005 06:11 PM
Bored out engines Ryan_310 Nova 2 07-08-2003 01:21 AM
