Old 07-06-2010, 02:32 PM
bonez007 bonez007 is offline
sub box help
hey guys need some help making a sub box.
just got a mutant 600w MT1007 10" Subwoofer, need to build a box but i can not work the calculators for the box dimensions.
specs are...
Max Power (Watts) 300
RMS Power (Watts) 150
Impedance (Ohms) 4
Frequency Response (Hz) 36-2500
Magnet Size (oz) 40
Voice coil diameter (inches) 2
Sensitivity (dB) dB (1W/1M) 87.6
Resonant Frequency (Hz) fs 32.557
Mechanical Q Factor Qms 3.809
Electrical Q Factor Qes 0.665
Total Q Factor Qts 0.559
Equivalent Volume (Ltr) Vas 35.185
DC Resistance (ohms) Re 3.6
Linear Excursion (mm) X-Max
Effective Piston Area (mm2) Sd 33.006
Mechanical Mass (g) Mms 105.066
Mechanical Compliance (mm) Cms 227.451
Force Factor ™ Bl 10.404
Reference Efficiency (%) No 0.179
Diaphragm Mass (g) Mmd 98.17
any help would be great
thanks
nic
Old 07-06-2010, 09:06 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: sub box help
http://www.bcae1.com/spboxnew2.htm
http://www.carstereo.com/help/Articles.cfm
http://www.linearteam.dk/default.aspx?pageid=winisd
http://www.ht-audio.com/pages/BassBoxPro.html
that should be a good starting point
Old 07-07-2010, 05:57 AM
Re: sub box help
wow thanks very much, the first link hit the spot
again cheers
nic
