Old 05-08-2003, 11:26 PM
el_loco_civic's Avatar
el_loco_civic el_loco_civic is offline
Send a message via Yahoo to el_loco_civic
Question Swap-able Radiator ?
Is there a Swap-able radiator for the sedans ? i need one that is Bout maybe, 6 inches or so less in width. Everything else like thickness and height is fine. But My projectors stick inward too much, and i have to modify radiator to fit them properly, means i have to cut corners off bout 3 inches or so deep. But then i'd have to saughter each lil ridge together, and i'm too lazy for somin like that. Being Mexican doesnt mean i like work.. :bandit:
But any help iz appreciated !
Civic - Trashed it
Integra - Hit and run totaled my ride after a couple 360*'s.. hittin guard rail at 80mph, literally FLIPPING over guard rail, barrel roll 2 more times, crashed front into a tree..
New Plans : Teggy / or / Tiburon
Old 05-09-2003, 01:35 AM
mellowboy's Avatar
mellowboy mellowboy is offline
Amy dragged me here...
Send a message via Skype™ to mellowboy
U can get a 6th gen civic radiator. Those things are pretty small but u have to customize it to fit it right. I can't tell you how since i never did it but i did see a crx with a 6th gen radiator.
Old 05-09-2003, 06:10 AM
-Alright thanks Mellowboy !
I'll try to get to a junkyard and check that out. Thanks again.
Civic - Trashed it
Old 05-09-2003, 07:54 AM
marked001's Avatar
marked001 marked001 is offline
Moderadur
Send a message via AIM to marked001
I dont know if the 6th gen rad is too tall or not..I know the 5th gen is... the neon radiator is a half-size rad and fits nicely...my buddy just did a write-up on this..lemme see if I can get/find the link..
*edit: found it... http://www.geocities.com/neonradiator/neon.html
SOLD!
Old 05-09-2003, 12:25 PM
91civicDXdude's Avatar
i know a 90-93 teg radiator will bolt right into a 88-91 hatchie... dont know about the sedans though..
Old 05-09-2003, 01:12 PM
marked001's Avatar
Moderadur
..I"m pretty sure that tegs use full-size rads...dont they?
SOLD!
Old 05-09-2003, 01:36 PM
mellowboy's Avatar
Yes they do.
Old 05-09-2003, 02:00 PM
gunnmen01's Avatar
gunnmen01 gunnmen01 is offline
Send a message via AIM to gunnmen01 Send a message via Yahoo to gunnmen01
do the 90-93 tegs use a radiator with more core's? otherwise its not worth the swap...
gunnmen01
My other ride..... is YOUR MOM !!!!!!
Old 05-10-2003, 10:34 AM
ev0lution7 ev0lution7 is offline
Send a message via ICQ to ev0lution7 Send a message via AIM to ev0lution7 Send a message via Yahoo to ev0lution7
yes the use a double size rad than our civics i'm thinking of going that route to keep my turbo'd ZC k00l (when i install my turbo) just cuz it looks like a BEEFIER rad
Crxce- theoretically if u laid a starter on a table and hooked up the wires would it run???
BLU CIVIC- no...it doesn't have any legs
Old 05-10-2003, 01:12 PM
EF You's Avatar
EF You EF You is offline
EF Life Giver
Send a message via AIM to EF You
STD hatches come with a slightly shorter radiator, they arent half size,but they are about 4 inches shorter than the Si radiators. try that one, it might work. i have three of them if you need one.
over 10 grand in parts, and about 300 hours of labor, and i only spent 3k. and then Katrina filled it with mud.
Old 05-10-2003, 01:21 PM
mellowboy's Avatar
Yeh same goes for the HF. I forgot abut that.
Old 05-10-2003, 03:18 PM
my brother has a 91 STD that the radiator cracked all to pieces so he put the 90 teg one in. bolts right in no problems.
Old 05-10-2003, 09:12 PM
Alright, that sounds pretty good. Thats w/ AC too ? And how much would you want for 1 ?
Civic - Trashed it
Old 05-10-2003, 09:24 PM
EF You's Avatar
EF Life Giver
yes. they have A/C fans on them. 10 bucks plus shipping and you can have one, fans and all.
