Go Back   Automotive Forums Car Chat > Nissan > Primera | G20 > Maintenance
Maintenance problems, fixes.
Old 11-02-2001, 08:24 AM
bkomonytsky bkomonytsky is offline
Unhappy G20 Radio Antenna
The antenna on my 1993 G20 does not go down. How difficult is it to replace it myself? I don'twant to go to the dealer and pay his outlandish service fees if I don't have to. Where can I buy a replacement antenna?
Old 11-02-2001, 12:28 PM
ales's Avatar
ales ales is offline
Forza Schumacher
It's very easy. Do a search in this section - it has been covered already.
I would suggest buying one from the dealer (you don't actually need the whole antenna, just the top (thinnest) link with the cable.
Seanzi could give you some pointers on where to buy it
Old 11-02-2001, 03:06 PM
ales's Avatar
Forza Schumacher
I post this email here for future reference...
> Thanks for your reply. I haven't taken anything apart yet, so I don't know exactly what the antenna assembly looks like. The antenna is motorized (it retracts when you shut off the radio), so if it refuses to retract, won't the entire antenna subassembly have to be replaced?
Not really. It seems to be a common problem on our cars. What I did was buy a used one from a Primera with a bad motor. It didn't quite fit and so I took the metal part (all the links) and it works fine now.
Can you hear the antenna motor work when you turn off the head unit?
Here is how it woks: the top (thinnest) link is attached to a plastic cable and the motor either pushes it out or pulls it in, and the first link, obviously, pulls or pushes the remaining links with it. If the cable breaks (most common problem) the cable is still able to push the antenna out, but not pull it in.
In order to replace the cable you need to replace at least the top link (they are not separable from the cableunless broken). I haven't really checked, but I think a guy that asked me for help a few months ago was able to purchase just the top link/cable. If not, your only option is the whole assembly, and there is no other sourse of those than the dealership.
In order to take out the antenna assembly you need to remove some of the trunk lining, unscrew three (IIRC) bolts or nuts that hold the assembly, and then unscrew a nut on the outside (on the fender) - use thin pliers or tweezers or whatever does the job.
There is also a tube that goes from the bottom of the antenna to the inside of the rear fender. You can either remove the tube from the antenna, of from the fender (together with a rubber thingie that holds it in place). I find the latter option *much* more easy.
You don't really need to take the whole assembly apart. And it's not hard at all anyway.
Good luck.
Alex Lamus
Old 11-03-2001, 12:32 AM
A380Driver A380Driver is offline
Send a message via AIM to A380Driver
Re: G20 Radio Antenna
I'll tell you what...replacing the antenna alone will not fix it. What is bent is the metal housing that the antenna retracts into.
If you search the SE-R mailing list archives
http://www.se-r-list.org/archives/
you should be able to find a post by me and others on how to take out the power antenna assembly and rebend this housing tube. You'll need to do that to make it go down, or buy a whole new unit from the factory.
-Brian Jones
I got a snake man
antenna stuck in down position...argh! scootergirl37216 3 Series 0 09-29-2009 05:09 PM
Radio antenna & XM Radio Tom-ADC Impala | Impala SS 2 11-23-2005 03:52 PM
Flexible Radio Antenna Install rednec Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 15 08-10-2003 10:45 AM
CB Antenna - opposite radio antenna Aussie Pathfinder | Terrano | QX4 | Xterra | Patrol | Safari | X-Trail 23 02-04-2002 10:39 AM
