Go Back   Automotive Forums Car Chat > Oldsmobile > Cutlass Series
Cutlass Series Includes Cutlass Ciera, Cutlass Cruiser, Cutlass Calais, Cutlass Supreme, Custom Cruiser, as well as the GM N-Body subforums.
Old 07-05-2010, 03:54 PM
Meck46 Meck46 is offline
95 Olds cutlass supreme coolant leak
Hi I have a 95 olds Cutlass supreme 3.1L engine loosing coolant no external leaks so I pressure tested the cooling system I could hear air coming from the oil fill hole and the oil is up 1 to 2L above normal, I need a little help to figure out if its the head gaskets or the Intake gasket, I'm not getting any white smoke from the exhaust. If someone can help to figure out which one it is would be great.
Thanks
Old 07-05-2010, 10:00 PM
Badfish169 Badfish169 is offline
Re: 95 Olds cutlass supreme coolant leak
Does your oil still look like oil or does it have a white milky look to it?
Old 07-06-2010, 12:11 AM
Hi it has a white creamy color to it, the oil and filter where just changed a week earlier, what I'm not sure of is if it the head gasket or the intake gasket, is there away of testing the head on the car.
Old 07-06-2010, 03:52 AM
Well... the white creamy look is because the coolant is mixing with the oil. Not sure if it's the head gasket or not.. I'm not a mechanic by trade.
