Old 07-05-2010, 12:14 PM
legotech7 legotech7 is offline
Terrible Rattling sound!
I have a 95 Sonoma that has this terrible rattling noise when I push the gas peddle to accelerate, and the noise subsides when it changes into gear. But every time I need to accelerate, you can hear this crazy sound, underneath like where the exhaust might be. I checked under the truck to see if anything might be loose, but everything is tight. Also the truck has like no power. The engine is a 2.2. Going up a hill, I have the pedal almost to the floor and she barely does 30 mph. Any one have any Ideas?
Thanks, legotech7.
Old 07-06-2010, 01:31 PM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: Terrible Rattling sound!
Thanks, legotech7.
Any codes or check engine lights?
Beat on the cat and see if it is lose inside.
Run a engine vacuum check for exhaust back pressure.
Post back engine vacuum at idle and at 2K RPM.
If less at 2k than idle you have a restricted exhaust system.
MT
Old 07-17-2010, 07:51 PM
NJH_Habitatpro NJH_Habitatpro is offline
Send a message via AIM to NJH_Habitatpro Send a message via Yahoo to NJH_Habitatpro
I have this same problem on my 95 4x4 vinW. Rattles while gasing then once it shifts it stops. vacuum might be a issuse due to pretty sure my brake booster is bad. Hear a hissing sound when hitting the break under my dash. But I also have the loss of power, just did a tune up on it to. so spark plugs wires and air filter are good and of course oil and oil filter.
Old 07-17-2010, 08:22 PM
So, did you resolve the noise issue? And if so, how?
Old 07-18-2010, 06:45 PM
I have not messed with mine yet i will post back if i find my problem ill be working on it wednesday.
Old 07-18-2010, 07:13 PM
No codes, No check engine light, no unusual sound coming from the Cat.Ill try to run the engine vacuum check and see what turns up. I'm a little newbie at this, how do I go about running the vacuum check?
Thanks for all advise..............
Old 07-20-2010, 04:40 PM
exalteduser's Avatar
exalteduser exalteduser is offline
Goober
Did you beat on the cat with like a rubber mallet? that really sounds like what it is to me is broken up pieces inside
1991 Jeep Wrangler 4.0 (3rd child or 2nd wife)
1999 Chevy Suburban 1500 5.7
2005 Toyota Rav4
1994 S-10 Blazer 4.3L "W" "Dead and gone"
