Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 07-04-2010, 11:30 PM
robertbrown robertbrown is offline
02 tahoe not starting
when I went to start it this morning I had no gauges,buzzers, or turn signals with the key in the on position. Did have hazards, windows and headlights. Back lights for gauges came on but nothing happens when you turn key to start position. have checked fuses and relays but found no obvious problem. truck was running great last night with no issues. racking my brain and need some help.
Old 07-05-2010, 02:20 PM
roadrunner2 roadrunner2 is offline
Re: 02 tahoe not starting
You may have a poor connection somewhere in the ignition system as some some lights and components work and not others.
Poor ground connections cause lots of problems.
Starters consume more power than any other electrical user on the vehicle.
Ensure ALL connections are clean and wrench tight.
Remove BOTH ends of the battery cables , clean with a wire brush (there is one made for this minor job) and re install wrench tight.
Check and ensure a clean, tight connection with the engine to chassis ground strap.
The problem with doing nothing is not knowing when you're finished.
Old 07-05-2010, 03:06 PM
Firehawk97 Firehawk97 is offline
Check your battery cables. Make sure they are clean and tight.
Old 07-06-2010, 10:56 PM
checked battery cables, all ends clean. tried replacing battery with different one to see if that was the problem, no change. any ideas of where i should go from here?
Old 07-07-2010, 10:20 AM
Try moving the shifter, maybe the PRNDL switch is out of adjustment. Try strating it in Neutral
