Old 05-08-2003, 11:58 AM
Deadboy's Avatar
Deadboy Deadboy is offline
Send a message via MSN to Deadboy
Unhappy Problem audio in car
Ok here is my prob.....i have a sound system in...amp.sub.speakers..and so on.......i connected every thing like in the manual....but ...the radio has up to 46 something volume.......and if max out the radio ...i hear just a littel of the music and the speakers make a static sound/more static then sound/.....but when i connect all the speakers with the sub ...it work nice....no static........and then prob 2) evey thing turn of after 10 min .....could the voltage be wrong?......the batteri is 12V and the amp and radio is to 12V....and the radio taks its voltage from the lighter...the ....it just wount work with the radio wires.....the last radio that was in when i got the car when up in smoke when i turnd it on:P ..it made a small boom sound and a lot of smoke came:P................ps sry about my bad english............but any ideas on wtf should do?
Old 05-08-2003, 02:58 PM
killah_xft killah_xft is offline
Send a message via ICQ to killah_xft Send a message via AIM to killah_xft
sounds like your amp is overheating... but could be something else... what kind of fuse are you running, whats the headunit/amp/subs? and how do you have it wired? do you have a speaker level converter on it? I tried one of those speaker level converters, and I could'nt get any sound (well I could, it was just so damn quiet I could barely hear it) and when I did a direct speaker level input to my amp from the front speakers it worked like a charm.
Black 1999 Honda Accord LX, Bombz Cold Air Intake, DC Sports Ceramic Exhaust header, "Rally racing" Foglights, 400 watt coustic 401SE AMP, 450 watt Bazooka TVB 141 Tri-vent triangle sub. 220 watt Pioneer 6.5" 3-way (in doors).
To come: Dynamat, Borla exhaust system, and 17" Koenig Absolute (black w/ chome lip), Coilovers, & camber kit (1-1.5 drop), Extensive Engine mods.
check me out on: http://www.cardomain.com/memberpage/515191
Old 05-08-2003, 04:14 PM
esp's Avatar
esp esp is offline
Send a message via AIM to esp Send a message via MSN to esp Send a message via Yahoo to esp
first off ever heard of sentences? it makes it easier for us to read.
secondly are the positive and negative wires running closely together because that can cause the static that you are getting. not to sure about the problem with the amp thou.
my guess is somethings are touching that shouldn't be touching with the smoke issue that you have goin on.
*RIP* Integr8 aka Ryan *RIP*
5/29/03
www.fotki.com/esp
THIS OG IS GONE retired for good. peace yall. create a crew for me
Old 05-08-2003, 04:36 PM
LB Dinh LB Dinh is offline
Did you ground it properly? To the metal chassis?
Originally a Radiator Fan Problem, Now Car Won't Start fiskee '91 - '96 2 09-09-2009 12:17 PM
Audio Problems Ismac Car Audio 3 08-08-2009 10:30 PM
Help with new car audio; Cade.Garrett Car Audio 2 07-02-2009 12:32 PM
Auto Audio Car Show South West Fl. splstats.com Car Shows 0 10-20-2004 11:05 AM
