Go Back   Automotive Forums Car Chat > Ford > Contour
Old 07-03-2010, 10:41 PM
rdkurth rdkurth is offline
1996 Ford Contour 2.0L I am having a charging problem
My Battery is not charging. So the alternator is not charging the battery.
I rebuilt the alternator with new brushes one of the old brushes was broken. Before I put it back into the car I took it to the parts store and had them test it. It passed all the test.
Put it back into the car but it still would not charge. Found that the Mega Fuse on the wiring harness was blown replaced it but it still will not charge
Where should I look at now?
Old 07-03-2010, 11:02 PM
inafogg inafogg is offline
Re: 1996 Ford Contour 2.0L I am having a charging problem
do you have 12v @ alt???
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 07-03-2010, 11:10 PM
Yes on the wire that conects to the MEGA FUSE and also when the key is turned on at the green wire on the three wire plug to the alternator
Old 10-23-2010, 07:07 PM
cmderus cmderus is offline
I am having same issue I put reman alt on today and I am getting no charge. Where is the mega fuse located
Old 03-21-2011, 03:42 PM
BOZZZ BOZZZ is offline
The fuse should be on the back side of the motor twards the firewall you will see the cables running to it. It has a black plastic cover around it.
Old 04-01-2011, 01:58 PM
FordMan59 FordMan59 is offline
Are you sure the battery is good?
