View Poll Results: WHICH DO U PREFER?
LS VTEC 3 21.43%
GSR MOTOR 11 78.57%
Voters: 14. You may not vote on this poll
Old 05-07-2003, 07:57 PM
wp?civichb wp?civichb is offline
Send a message via Yahoo to wp?civichb
Question Which Do You Prefer?
I WONDERING WHAT WOULD BE THE BEST SWAP?:smoker2:
Old 05-07-2003, 08:06 PM
Moppie's Avatar
Moppie Moppie is offline
Master Connector
Please turn the caps off
And just what is an LS VTECK?
Old 05-07-2003, 08:11 PM
ls vteck
SORRY An ls vteck is an ls block with a b20 head formally known as a frankenstein motor.
Old 05-07-2003, 08:21 PM
Worshp's Avatar
Worshp Worshp is offline
Is that the same as a veetech
Old 05-07-2003, 08:23 PM
Moppie's Avatar
Master Connector
Re: ls vteck
Then I think you mean an LS VTEC.
Iv never heard of VTECK.
And since the B20 is not normaly a VTEC engine, then I think you actualy mean an LS block with a B18c or B16a head, which yields a higher compression ratio and slight larger cupic capcity than a B18c.
The B20 VTEC is a B20 block fitted with either the B16a or B18c head to give it VTEC.
Both are known as Frankenstien engines.
Fitting a B20 with an LS head sounds a bit silly to me, as I think you will find they both share the same head (or a very similar one)
And in all cases I would have to choose the B18c, while the LS and B20 VTEC have been proven to work, I dont think the gains from the extra capacity are worth the amount of work required, or the still unresolved reliablity issues associated with matching a block, cranks and rods up to a head it was never designed to take, and useing the combo to produce hp numbers they were never designed for.
With the right work done to a B18c the same gains can be realised with out the same sacrifices to reliablity.
Old 05-07-2003, 08:25 PM
Moppie's Avatar
Master Connector
A post by Moppie, followed by a post from Worshp, followed up by another post from Moppie!
Are the JDM Duo back to terrorise the 4g forums yet again?
Stay tuned Honda fans, same Honda forum, same Honda threads!
Old 05-07-2003, 08:26 PM
yeah a ls veteck is a b18 block with a b20 head which is pretty high compression motor i think its like 10:5:1 and a gsr is think 91. which would make the ls vteck a faster motor about as fast as a type-R.
Old 05-07-2003, 08:29 PM
Moppie's Avatar
Master Connector
:huh: :huh: :huh: :huh: :huh: :huh: :huh: :huh:
Hey kid I can hear your mommy calling, something about you need to go back to kindergarden.
Old 05-07-2003, 08:31 PM
ci5ic's Avatar
ci5ic ci5ic is offline
worlds tallest midget
Okay... aparently Moppies subtlety went unnoticed...
It's VTEC not veteck or vtek or vteck or vtech... Personally, I don't care what you call it, I know what you mean, but some people get their panties in a bunch when they see it spelled wrong, and they'll give you a rash of crap about it...
Just a helpful hint.
Old 05-07-2003, 08:32 PM
Worshp's Avatar
LS/VTEC = B18 block, B16 head.
CRVTEC - B20 Block, B16/B18C head aka Frankenstein.
What B20 head is a VTEC head?
Old 05-07-2003, 08:33 PM
WHY DONT YOU GO MOPPIE TO YOUR MOMMY AND SUCK ON HER TIT.
BUT THANX FOR THE INFO.:finger:
Old 05-07-2003, 08:36 PM
Worshp's Avatar
If she looks anything like Moppie then that's a damn terrible punishment for the poor guy
FYI, there is no such thing as B20 VTEC head.
Old 05-07-2003, 08:39 PM
Moppie's Avatar
Master Connector
:finger:
Im missed a class this morning and Im bored!
I consider any mixing of parts that were never intended to be together to create something new as a Frankentein.
So the LS/VTEC, or a non VTEC D series fitted with a SOHC VTEC Head, or a 4agze fitted with a high port 4age head, or a 240z fitted with an RB26det, or a non EF9 4g fitted with a B16a etc etc etc
I HAVE REALIZED MY MISTAKE AND THANX FOR THE INFO.
Old 05-07-2003, 08:40 PM
Moppie's Avatar
Master Connector
To ban or not to ban, that is the question
excuse me while I check I.P.s
