Go Back   Automotive Forums Car Chat > Toyota > Corolla/Matrix/Voltz
Old 07-02-2010, 10:30 PM
dnmir54 dnmir54 is offline
Smile steering whine?
have a 2008 matrix when i turn the steering wheel to the left i sometime at least once a day get a high pitch whine ,fluid is good and am not able to make it whine when i need it to like for the repair technition
any thoughts?
Old 07-03-2010, 09:28 AM
adamba adamba is offline
Re: steering whine?
Try turning it further to the left, until it stops turning. Most people don't understand that when the steering wheel is turned all the way until it stops turning, the pump pressure goes to over 3 - 4 times what it does by just turning it a little, and if you do this when the vehicle isn't rolling forwards or backwards, it will overheat your power steering fluid. The groaning sound is the pump complaining about the high hydraulic pressure. The first to go is usually the seals in the hoses, which causes a loss of fluid, followed by a damaged pump. A lot of people don't check their new car for proper fluid levels unless they see a puddle in their driveway. If you hear a groaning, the pump may have been already damaged - start saving for a new one and don't forget the hoses.
Old 07-09-2010, 10:43 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Re: steering whine?
Steering pumps have to work harder to turn the front wheels when the car isn't moving and the roughness of the pavement surface can affect it too.
If this is a recent development, you should be covered under warranty. At the least, you should take it in and have the issue documented. If future work is needed, you have proof the problem began during the warranty period.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
