Go Back   Automotive Forums Car Chat > Dodge > Ram Van
Old 07-02-2010, 03:51 PM
stnich stnich is offline
94 ram van 5.2. intermittent elec/start prob
Replaced pick-up coil,ignition coil and crank position sensor.Will start then run fine for a day,week or more. Then,while running it will die.It will turn over, but it wont fire. Sit for a couple hours or a day,then starts. Plenty of fuel and compression, but no spark.
Old 07-02-2010, 04:51 PM
alloro alloro is offline
Re: 94 ram van 5.2. intermittent elec/start prob
It's a bad ASD relay or a bad PCM (computer.) What's happening is when either one of these is getting hot, it stops working until it's cooled down.
Old 07-02-2010, 05:00 PM
It will do this sometimes after running 30 seconds. It usually happens in first 5 minutes. It will run for days/weeks sometimes no problem.
Old 07-14-2010, 12:11 AM
Tommy2500 Tommy2500 is offline
I agree with alloro- replace the ASD relay. PCM is another matter - lots of
good used ones out there if you look. Don't go out and buy a "rebuilt" like
I did and got the shaft for mass $$$. I'd also look at the grounds. My
intermittant problem on my Van ended up being both bad wiring (inside
the harness..left side of the motor between intake and valve cover) AND
a bad connector to the crank sensor. Crappy wiring on these years
Dodges - a trusted dealer told me MANY warranty problems. Keep looking;
you'll find the cause. Good Luck.
Tags
b250 , dodge , ram , van
