Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 07-01-2010, 05:31 AM
KUH3NS KUH3NS is offline
95 eclipse 420a wont start
ok here is my problem i have a 95 eclipse 420a that wont start it will crank over all day but there is not spark and the fuel pump wont kick on..it ran fine when it was shut off,now it wont start..could it be the ecu or what could it be..i am new 2 the whole dsm thing so i hope some one can help
Old 07-01-2010, 10:48 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Re: 95 eclipse 420a wont start
Welcome to AF.
So the car ran fine, and it shut off unexpectically while driving and now not starting? Are you positive there is no fuel and / or spark?
Firstly, check the battery to make sure it has proper voltage. I would check all the fuses and relays first. Would also check timing to make sure it didn't skip at some point and causing you to lose compression.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 07-01-2010, 11:19 AM
No The Car Ran And When i Shut it off and went 2 start it again it wouldnt start.i have checked all the fuses and they r fine.and i am positive that it isnt gettin spark or the fuel pump isnt kicking on.the fuel pump will only kick on if i run a 12+ volt from the battery.
Old 07-01-2010, 08:30 PM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I had the same issues once, the main engine fuse was blown under the hood. If thats not your problem then the ECU is not providing power to the pump, injectors, coil pack for some reason. Dont make much sense that it just stopped working one day but I would test cam position sensor. Crank position sensor, go ahead and test the map sensor while your at it.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 07-04-2010, 04:06 PM
hey i put a new ecu in it and it runs fine now
Tags
eclipse
