Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-30-2010, 05:04 PM
LieutenantCracker's Avatar
LieutenantCracker LieutenantCracker is offline
96 Town Car a/c only works for 10-15 mins
The air conditioner in my 96 LTC blows nice and cold until about 10-15 min's after the engine warms up.
Upon a cold-start, I turn it on, w/ the EATC set on 60. The compressor immediately kicks-on, runs for about 5-8 sec' then switches off for 5-8 sec's. It does that four to five times before the comp. runs continuously, as it is supposed to do.
The black cylinder that's next to the coolant reservoir-- the condenser (evaporator, maybe?)-- Whatever it is... It becomes cold to the touch, and *Condensate builds-up on its outer surface, as it is supposed to.
So, after 10-15 minutes, the compressor will shut-off for 5-15 secs, then kick-on for 5-8... And just keeps going through that cycle and the inside air quickly becomes warm.
> I recharged the system about three wks ago, and it does blow noticeably colder... When it's working for that 10-15 minutes, that is.
> I am unable to get the EATC to enter test mode. Pressing OFF & FLOOR simultaneously, then while holding those two buttons down, pressing AUTOMATIC is supposed to do it. Am I doing something wrong?
*Just a little fun-fact: Contrary to popular belief "condensate" is the actual water itself that forms on the outside of a container which is colder on its inside, than the outer air temp (a glass w/ ice in it, for example)-- "CONDENSATION" is the process which causes the condensate to form. [I didn't know that 'til recently(!)]
________
LovelyWendie
Old 06-30-2010, 05:36 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 96 Town Car a/c only works for 10-15 mins
When you filled the system with refrigerant, did you also check for proper low and high pressures, temperatures, and vacuum?
http://p71interceptor.com/actuneup/pictures/
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 06-30-2010, 07:07 PM
Yes, I did.
I was experiencing the same problem before as well as after the recharge, if that makes a difference.
Shortly after I posted my original msg., I figured out how to enter test mode on the EATC. It gave me code "025". any idea what that means?
________
Lovely Wendie99
Old 06-30-2010, 07:50 PM
All2kool's Avatar
All2kool All2kool is offline
Originally Posted by LieutenantCracker View Post
Yes, I did.
EATC Code 025 is for a Blend Door Failure. I found this answer in less than 30 seconds via Google.
Old 07-01-2010, 12:38 AM
Thank you, all2kool...
I, as well, found that info through Google.
The reason my previous reply included that question was b/c I hoped that someone might have some insight, in addition to what I had found elsewhere. But, I thank you for the condescension (Please forgive me, & correct me if I've misinterpreted your posted reply)
________
Medical Marijuana Dispensaries In The Inland Empie
Old 07-01-2010, 08:17 AM
All2kool's Avatar
Condescending I was not, applauding Google I was. To have avoided confusion, you should have included what you had already found out perhaps.
Old 07-02-2010, 08:03 AM
Ah, crabs!
Sorry 'bout that, man! I thought you were making fun of me.
And, you're right-- I should've posted the info that I'd found... I suppose I was the one who made things confusing, that time
THANKS for the replies!
PS [UNRELATED TO THE CAR ITSELF] Is there any way to express inflection/tone/feeling, in an e-mail, other than using those dumb little emoticons?
THIS was a prime example of a time when I needed to show that *I* wasn't being condescending-- But I still feel like a tool having to use a stupid "smiley"!
________
YAMAHA MOTIF HISTORY
Old 07-02-2010, 08:57 AM
All2kool's Avatar
Ah, crabs!
In your defense, I can be a butthead sometimes, but this wasn't one of them.
Old 07-06-2010, 01:55 AM
I did a little searchin'-around Google, lookin for info re: whether the "025" (blend door) eatc code could have anything to do w/ the compressor kicking on and shutting off-- Couldnt find anything.... I've been known to phrase my Google searches properly, though.
Have any idea if that blend door issue would cause my problem?
________
Alaska medical marijuana dispensaries
Old 07-06-2010, 07:06 AM
radioconsult radioconsult is offline
Replace the AC pressure switch, located near the expansion chamber. It's a Schrader fitting so no need to empty the system.
