Old 06-30-2010, 09:28 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
Headlight Switch
Anyone ever replace the bulb(s) in their headlight switch?
Mine recently burned out. Man is it annoying when dash lights burn out.
Just wondering what I am up against cause I've never had one out. Are they little bulbs soldered in, or is it one bulb that is replacable?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 06-30-2010, 10:14 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Headlight Switch
I believe they are soldered in.
Old 06-30-2010, 12:58 PM
00GTP4ME's Avatar
00GTP4ME 00GTP4ME is offline
Sounds like another write-up for you to do Tim!
2000 Pontiac Grand Prix GTP 3.8L SII V6 S/C
2000 Jeep Grand Cherokee Limited 4.7L V8
1996 Chevrolet Camaro Z28 5.7L V8
1993 Chevrolet Suburban K1500 5.7L V8
1991 Ford Probe LX 3.0 V6
1986 Ford Tempo GL 2.3L 4 cyl.
Old 08-02-2010, 03:52 PM
Brent S Brent S is offline
It's on my list of things to do, also...........it's the only bulbs that don't work on my dash.
I already did the driver information panel backlights, and the radio backlight......I just need time for this one.
-Brent
'99 GTP
Old 08-03-2010, 07:36 PM
tblake's Avatar
In God We Trust
I just got a 20.00 replacement for mine at the junkyard. I still have the old one, I may take it apart and see what type of bulb is in there.
Old 08-04-2010, 12:12 AM
00GTP4ME's Avatar
The bulb in my heated seats switch is out so one of these days I'm going to attempt to put an LED in there too.
Old 08-04-2010, 09:10 AM
tblake's Avatar
In God We Trust
Matt, did you ever get your outside temp to display correctly on the HVAC?
Old 08-04-2010, 09:20 AM
00GTP4ME's Avatar
Yep. The doinks just forgot to plug the sensor back in.
Old 08-04-2010, 01:30 PM
tblake's Avatar
In God We Trust
Sweet! I knew that was your issue. Mine did the 50 degrees outside temp issue too when I first bought it. I traced my issue back to a connector near the battery compartment that was covered in battery acid and corroded badly.
