2001 Express Van / no trailor brake lites
I have this 2001 Express Van with factory trailor , 4 pin hook up . I have no trailor brake lites . all lites work on the van , turn signals & running lites work on the trailor , just no B/L . I'm sure I caused this as I had a trailor with 2 wires crossed ( which I have corrected ) . I understand there is a board or module that runs or isulates the brake lites as they are independent from the turn lites on the van . Have check all fuses under the hood and inside kick panel . Any idea where this board is located or any other possible fuses which mite cause this . Thanks
David |
Re: 2001 Express Van / no trailor brake lites
If it has the trailer wiring package the module is right rear of cab interior. Check for brake light and turn signals going into it. Turn signal wires will be yellow and dark green. For wiring diagram on it you will need a factory repair manual or contact All data and see if thy have it in there repair DIY programs. Good luck
It is a 1/2 ton ,8 passenger van with factory towing . And by rite rear of cab , do U mean in the side panel at the back of the front pass. seat ? I looked in the rite kick panel and saw nothing but a lot of wires only . and also took the panel off at the rite back side where the tail lites are and only found wires , no module . Thanks for ur help
David |
But I do not show it on or for a 1500 1/2 van. Just trailer wiring there. You need to try all data or get a factory repair manual on it for more details. http://www.alldata.com/products/diy/index.html If only a 4 pin trailer plug it does not have brake lights separate on a brake light wire. The turn signal and brake lights will be together. Which you can just tie into your van rear light. Does the brake and turn signals work right on the rear of van? Trace your wires from trailer plug and see if they run into your rear van light wires or go on up front. Let us know what you find there.
Yes all lites on the van work properly . but the turn -parking lites are one and the brake lites are a separate lite by there self . I will trace this further , as far as I can , and get back a bit later or 2morrow .
David |
You need a special adapter in betweeen the trailer to van connector to get this to work because of the seperate lites on the van, you can get this at most parts stores.
The trailor brake lites have always worked until I hooked up a trailor that had a wire crossed , since then , they no longer work on any of my tailors .This special adapter U talk about (or at least the equivalant )I'm pretty sure was included when the factory package was installed . This is where I think my problem is ,(in this module ) but where is it ? I see that the wiring harness goes down the left side of the roof to the dash but can not find any thing that looks like a board or module under the dash .
Usually it is back by the rear harness under under the chassis.
