Go Back   Automotive Forums Car Chat > Ford > Ranger | Courier
Old 06-28-2010, 08:50 PM
timd timd is offline
Windshield washer squirters
2002, Driver's side squirter sprays water but not the passenger side. Tried cleaning the passenger side squirter orifice with a pin. Seemed to have some build-up. Pin goes in now but still won't squirt water. Looked at the hose connections under the hood and they look OK. Main hose runs to the driver's side and a T splits off for the passenger side. Anyone have any experience with this? Don't want to cause more problems if I can help it. Thanks to all that reply!
Old 07-20-2010, 05:57 PM
Re: Windshield washer squirters
Tried pulling the hose off the firewall but looked like I was going to destroy the hose before it would come loose. So, I mixed up a solution of 1/4th vinegar and 3/4ths water and filled my reservoir. After only one day of occasionally using the washers, the passenger side started working. Since it was misting outside anyway, I kept using the washers as often as possible to purge any crude out of the line.
Old 07-22-2010, 05:12 AM
Davescort97 Davescort97 is offline
Escort guy
Thank you for letting us know a tip to unclog wiper sprays. I've never heard of using vigegar and water, but if it works. That's great.
Old 02-20-2012, 08:33 PM
I figured if vinegar works on cleaning coffee makers, it should work on the squirters.
The Following User Says Thank You to timd For This Useful Post:
BowtieS10 (03-26-2012)
