Go Back   Automotive Forums Car Chat > Pontiac > Trans Sport
Old 06-28-2010, 07:36 PM
Ben Fury Ben Fury is offline
Ignition Cylinder Replacement
My keys went missing and the GM computer has the wrong key# for my VIN so the replacement keys from the dealer don't work. Going to have to replace the ignition cylinder to get my 1992 TransSport back on the road.
Anyone done this? Any tips? Is there a good manual to refer to for a good exploded view to understand what I'm working on?
Thanks,
Ben
Old 07-01-2010, 02:49 PM
Jrs3800 Jrs3800 is offline
Re: Ignition Cylinder Replacement
Its not a super hard Job.. I have done a few of these on the GM's... Once you do one you can make it look like a cake walk..
You will want puller to yank the steering wheel, then you will need the Steering wheel lock plate removal tool, not sure if the parts stores rent those.. A set of picks or small flat blade screw drivers could come in handy..
You will have to be very careful about taking the parts inside the column apart as they need to go back in the exact same way they came out..
Wish I had a write up or a diagram for you..
Old 07-02-2010, 01:15 PM
LMP's Avatar
LMP LMP is offline
www.avigex.ca/xport/steeringwheel.jpg
www.avigex.ca/xport/steeringcolumn.jpg
YOu posted the same also in the APV and Silhouette forums...Please remove your posts in the APV and the SIlhouette forum (click EDIT then DELETE) as it is duplicated in the transport forum.
'93 Ponty Transport 3.8; 2011 SUzuki SX4 AWD (wife's) ; 2015 Sorento 2.4 AWD 1928 Graham Paige Model 629
I don't believe in miracles.
