Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-27-2010, 11:29 PM
camarogolfguy's Avatar
camarogolfguy camarogolfguy is offline
Send a message via AIM to camarogolfguy
08 Recall heated washer fluid system
Anyone familiar with this recall?
Old 06-30-2010, 08:05 AM
j cAT j cAT is offline
Re: 08 Recall heated washer fluid system
the GM fix is to disable it ...then they give you a 100.00 .
if they mounted the washer fluid on the / near the fire wall this heating of the fluid would not be necessary...
Old 07-01-2010, 10:43 AM
Firehawk97 Firehawk97 is offline
There are 2 heated washer recalls. The first one was to add a fused jumper harness to the heated washer pump. And the second was only for VIN specfic vehicles where they found printed circuit boards had melted.
#08048C was the first and #10153 just came out in June 0f 2010.
Old 07-04-2010, 09:12 PM
Pats1999 Pats1999 is offline
Take your $100 from the dealer... Make sure they cut NO wires on the truck, they should only cut wires on the heater unit itself..
Then go buy this:
http://www.alphathermusa.com/heatedwash-AT-37GM.html
You'll still have money to pocket afterwards!
(This is my plan!)..
2003 Bonneville SSEi
2008 Suburban LTZ
