Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Tahoe
Old 06-27-2010, 07:40 PM
totalpackage's Avatar
totalpackage totalpackage is offline
Need help identifying this part!!!
I have a 96 5.7 liter Tahoe and had a noise coming from a boot that looks simililar to a spark plug boot. But now this boot that I need to replace has at the end of it a pcv valve in it which I think plugs into the block. The whole harness/boot/pcv valve is about 8 inches long. What is the proper name for this harness? Advanced auto had no idea what it was. Maybe a gm # would help me for this also.
Old 06-29-2010, 07:27 AM
j cAT j cAT is offline
Re: Need help identifying this part!!!
the pcv plugs into the block , the 3/8 inch fuel line / vacuum hose goes from the vacuum source to the pcv then the pcv plugs into the block....
PCV can make ticking noises...these should be replaced 20-30,ooomi...they wear out and then do not regulate crankcase vapors..
Old 06-29-2010, 05:31 PM
Thanks, that the exact part. Can anyone give me this part number?
Old 06-29-2010, 08:18 PM
any part store will have the pcv for your vehicle,,,then just get the same hose dia should be 3/8inch by how long you need ..if 8 inches buy 12 inches cut to fit ...
what you want a GM part number or something ???? THIS IS NOT REQUIRED OR I DOUBT EVEN IN EXISTANCE WITH THIS VEHICLES AGE !
If this task is above you abilities bring to a repair shop ..this should be less than 100.00 to correct..
Old 07-03-2010, 08:49 PM
Thanks, found the part # and the dealership had it that I went to for $9.93
I should have just went to the dearship 1st.
