Old 06-27-2010, 09:35 AM
charger73 charger73 is offline
Mustang won't start
I have a 98 v6 Mustang (automatic) with 104,000 miles. Wife parked it the other day, put it in park and it rolled. She didnt think anything of it until she went to start. Turn the key and nothing happens. Dash light up as normal but no sound from starter. When she told me what happened when she parked I tried the shifter and it just floats. Remove the emergency brake and the car rolls.
Not sure if it is just a cable or if something more serious with the transmission. Car had been running fine up to this point.
Any suggestions would be appreciated!
Old 06-27-2010, 11:03 AM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: Mustang won't start
Sounds like a problem with the shift cable. It is attached to the transmission on the driver side. See if it moved when the gear shift lever is moved. You may have to open the pan up and see if the rooster comb spring is in place, too. It may have broke some how.
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 06-27-2010, 06:22 PM
Smile Re: Mustang won't start
Thanks, I will check into that.
