Go Back   Automotive Forums Car Chat > Chevrolet > Malibu
Old 06-27-2010, 12:08 AM
mhowe1182 mhowe1182 is offline
problem bleeding the brakes
just was wondering if anybody has came across this problem before i cant get the brake pedal to get stiff and i have tried almost every thing and cant find what needs to be done. the cars is a 1999 malibu
1999 k1500 350 hd tranny
8 inch lift
35" tires
Old 06-27-2010, 07:34 AM
FISH96 FISH96 is offline
Re: problem bleeding the brakes
perhaps it may be useful to tell the folks on this forum how you came to this situation.
which did you r/r pads, calipers, brake shoes, wheel cylinders, hydraulic hoses, master cylinder or any combinaton there of.
someone from here will lend you a hand.
Old 06-27-2010, 10:12 AM
maxwedge maxwedge is offline
A990 racer
Exclamation Re: problem bleeding the brakes
100% agreed, the original post is useless regarding any info that would lead to a reasonable answer.
Old 06-27-2010, 10:51 AM
i changed the pads,rotors and calipers on it
8 inch lift
35" tires
Old 06-27-2010, 02:28 PM
manicmechanix manicmechanix is offline
Maybe you got air into the master cylinder when you unhooked the calipers and the fluid went too low. It would need to be bled at the ABS unit. There should be bleeders there. They are hard to get to but can be bled manually.
Old 07-03-2010, 04:35 PM
how are you progressing? is she now roadworthy?
