Old 06-26-2010, 10:46 PM
12Ounce 12Ounce is offline
Runs great ...then seems to "fuel starve"!
99 3.8 Winny. Runs great at start-up, then after several miles begins to act as tho starving for fuel. No power. Won't pull hills well. Stopping, then restarting engine seems to reset "whatever" and the van runs great again ... for a while. The restarting has the same effect if van is still moving.
The problem got so severe that the engine would actually die ... only then threw codes P0171&4...nomally does not light off CEL.
What will reset in such a manner?
Since problem began, I have done following...all at the same time:
.Changed plugs.
.Removed and lubricated synchro shaft.
.Replaced DPFEgr sensor.
.Cleaned crank and cam sensors.
.Replaced fuel "regulator" and in-line filter.
.Replaced intake air filter.
This all seemed to make van run much better, but the problem is still there ... perhaps not as severe. Restarting will still cause a "reset"!
I'm thinking failing fuel pump ....(haven't had chance to measure pressure)?? Any better guesses? MAF? Ignition pack?
Old 06-26-2010, 11:00 PM
serge_saati's Avatar
serge_saati serge_saati is offline
Send a message via MSN to serge_saati Send a message via Yahoo to serge_saati Send a message via Skype™ to serge_saati
Re: Runs great ...then seems to "fuel starve"!
Have you tested fuel pressure?
A bad weak fuel pump can cause that. When it turns off, it rests and works better after.
I don't have other relevant ideas.
2003 Chevrolet Impala LS 3.8L OHV
2002 Ford Taurus SE 3.0L OHV (sold)
1998 Ford Windstar LX 3.8L OHV (sold)
2002 Chevrolet Malibu LS 3.1L OHV (sold)
2004 Hyundai Accent GS 1.6L DOHC manual (sold)
1995 Oldsmobile Cutlass Supreme S 3.1L OHV (sold)
2002 Ford Crown Victoria Police Interceptor 4.6L SOHC (sold)
A Windstar without having the check engine light is not a real Windstar.
Old 06-27-2010, 05:21 AM
No,I haven't tested pressure yet ... sometimes it can take an hour or so for symptoms to occur. Long time to drive around with gauge in place.
I'm considering dumping and dropping tank ... just don't have anywhere to store 20+ gallons of fuel right now.
Old 06-27-2010, 07:44 AM
Lol, you can store them in my tank, I'm empty.
Seriously, it worths to drive many hours with the gauge taped outside windshield, rather than dumping the tank immediately.
The best way to test the pump is to to check also the direct fuel pressure from fuel pump (not just from fuel port).
A quick test is to block off the return line and see if fuel pressure comes up to 55-65 psi.
But do not run the pump more than few seconds for this test.
Old 06-27-2010, 11:52 AM
Well, I'm too desperate to be sensible ... already removed the pump. AutoZone has one they say.
This pump has over 200k on it ... so it doesn't owe me much!
Old 06-27-2010, 01:03 PM
200k miles for a Motorcraft pump! Impressive!
Old 06-27-2010, 01:31 PM
On more careful thinking, maybe it's more like 170k miles. The new one is going in!
Old 06-27-2010, 07:54 PM
Took all day long to finish job ... we'll see if it did any good.
Old 06-27-2010, 09:16 PM
olopezm's Avatar
olopezm olopezm is offline
Send a message via MSN to olopezm Send a message via Skype™ to olopezm
Hi there! I would like to know if changing the fuel pump fixed you problem because my 2000 windstar makes the same. Also I would like to know if you could send me an image with the pinout of the MAF sensor as serge_saati pointed me to check the MAF sensor but he only has a pinout up to '98 windstars.
Here's a link to my thread:
http://www.automotiveforums.com/vbul....php?t=1023465
Thanks for your reply.
Old 06-28-2010, 06:06 AM
It will take me some time to get to your request ... as I am now travelling. Hopefully some else has that information.
Old 06-28-2010, 10:33 AM
olopezm's Avatar
I have already found the diagram on the internet thanks anyway. I would really appreciate if you can post the result after changing the fuel pump as soon as you can.
Best regards...
Old 06-28-2010, 09:59 PM
Well, after driving 600 miles today... I am convinced the new fuel pump solved most of my symptoms. The car has plenty of power and accelerates well at all speeds. HOWEVER, after the first 200 miles, I picked up a CEL and the engine is not totally smooth especially around 70mph... I have not had a chance to have the code read. I was pretty beat when I was reinstalling the tank ... probably messed up a vent hose or something. May take a few days before I can have code read.
Old 06-28-2010, 10:08 PM
olopezm's Avatar
I see, well I guess I'll give it a try. Thanks for your time.
Good luck!
Old 06-28-2010, 10:15 PM
If I had had more time, I would have done some testing prior to beginning the work .. like already written, a pressure gauge taped to the windshield will give a lot of information.
Old 06-28-2010, 10:19 PM
olopezm's Avatar
Yup, that's what I'm going to do tomorrow, I've been traveling and kinda busy too, but tomorrow I'll have free time so I'll start inspecting the fuel pressure and maybe I'll try cleaning the MAF and the intake boot. Thanks again.
Best regards...
