Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 06-26-2010, 04:40 PM
aha825 aha825 is offline
91 Alternator
I got this '91 Town Car a couple months ago. It wasn't driven much by the previous owner. Anyhow, stopped to fuel up today, and when I went to start the car back up the engine wouldn't crank over. Asked one of the mechanics in the garage if they'd help me out. He tested the battery, it was fine. Jumped my car and said I need a new alternator.
What I want to know is will an alternator from a '94 Crown Victoria work in my car?
Old 06-26-2010, 07:08 PM
All2kool's Avatar
All2kool All2kool is offline
Re: 91 Alternator
Here's a thought - go to your favorite Auto Parts website (O'Reilly, PepBoys, AutoZone) and check.
The short answer is YES, the trailing (2nd) part number for either part for either car is the same. The Panther Platform for both vehicles came with the 4.6L EFI V8; many of the parts are interchangeable.
Old 06-26-2010, 08:28 PM
Blue)(Fusion's Avatar
Blue)(Fusion Blue)(Fusion is offline
Send a message via AIM to Blue)(Fusion Send a message via Yahoo to Blue)(Fusion
Re: 91 Alternator
An alternator from a civilian '94 Crown Vic will work although there are two types used for those years, a "small case" and a "large case". One from a Police Interceptor (VIN P71) will NOT work without modifying the wiring harness.
See this page for more information and part numbers:
http://p71interceptor.com/alternator/modelnumbers/
2000 Mercury Grand Marquis LS
- 119k / 14.89s @ 92.11MPH [ pictures | videos ]
> Dual Flowmaster Delta 40s / J-Mod / PI Intake Manifold & Cams / Marauder Air Box & 80mm MAF / 3.55 Trac-Lok
> Bumper Tuck / Steeda UD Pulleys / CVPI Zip Tube / Ported & Polished Plenum / BBK 70mm TB
> BOC 93 Octane Tune / Headlight Relay Upgrade / 17mm rear stabilizer bar / Heinous Aluminum Billet Rear Control Arms
> CVPI aluminum driveshaft
Old 06-26-2010, 08:40 PM
All2kool's Avatar
Re: 91 Alternator
And if you plan on adding a 1000w stereo, you'll be wanting the 'P' Code Alternator and all it's 190 or more AMP's of power; just as a Police Vehicle would need.
Old 06-26-2010, 10:55 PM
Re: 91 Alternator
Which would require said wiring harness upgrade.
You can even upgrade to a 6G alternator but you will have to make a custom top mounting bracket. And this is required, unlike on the 98+ model years where this bracket is only crash bracket.
