Old 06-26-2010, 03:59 PM
ricnor ricnor is offline
Radiator leaking
1997 K2500 with a 454 vortec engine and auto box. The radiator is loosing water from where the auto box cooler is connected, it looks like there is a seal gone from the inside of the radiator header, is there a way of fitting a new seal without taking the radiator apart, does anyone know where I can get the correct seal from or if it is actually a part that is available in the first place.
Old 07-07-2010, 09:41 PM
Vandalize Vandalize is offline
Re: Radiator leaking
Mine did that as well, though I only ended up tightening the nut on the outside that holds the fitting that the cooler line attaches to. It was leaking a lot of coolant and now doesn't leak at all. Hopefully yours can still be fixed this way.
Old 07-08-2010, 02:36 AM
Thanks for the reply at least I know it is cureable, however in this case not as easy as your one. The first thing I did was try to tighten it up but it didn't seal the leak so now I am going to see if I can get a rubber seal and insert it into the header and re-tighten the nut. Fingers crossed as it will cost a small fortune over here for someone to split the tanks from the core and re-seal and on top of that the radiator is in great condition apart from this issue.
Old 07-09-2010, 08:23 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Always find for sure where it is leaking.
Plastic tank rad are bad about cracking in that area.
If so a new rad is your best fix on them.
MT
Old 07-09-2010, 12:00 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I had a coolant leak like that too. As mentioned, tighening the big nut that holds the tranny cooler fittings eliminated the leak.
If the seals are truly gone, then you might try and squeeze some coolant compatible silicone into the crevice between the cooler fitting and the rad tank...won't be easy though.
Good luck!
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
