Go Back   Automotive Forums Car Chat > BMW > 7 Series
Old 06-26-2010, 10:47 AM
reino134 reino134 is offline
Send a message via AIM to reino134 Send a message via MSN to reino134 Send a message via Yahoo to reino134
2004 745i no power to cigar lighters
I checked all power outlet fuses and they test good. Still cannot figure out why I cannot get the outlets to work. Any ideas would be greatly appreciated
Old 06-27-2010, 02:07 AM
lincolnmaster80 lincolnmaster80 is offline
Re: 2004 745i no power to cigar lighters
What have you checked and have tried?
1990 E32 750iL --> Pictures
Production: 02/1990
Johan and Sean's E32 Page - Repairs and How-to's
E38.org - Information and tech tips for BMW's
Shogun's E32 Tech-Tips
Gale's Repair Page
ETK Online
Old 06-27-2010, 06:22 AM
I checked all fuses in the main block in the trunk, and also checked the ones in the fuse block in the glove box. checked them with an ohm meter. I have no blown fuses that I can locate. All 4 power outlets are dead. Has to be something simple and i just cant locate it!
Old 06-27-2010, 07:20 AM
I have power to the 50 AMP fuse but nothing from the 50 AMP to the 2 20 AMP fuses in the block. Also just realized that the 3 lighters are not lighters at all! They are just plastic plugs covering the outlets. Any ideas? I know that this was a previous lease vehicle..
Old 06-27-2010, 11:59 AM
The general consensus is that fuses are the problem, the ones in the glove box. For good measure, I usually replace the fuse with a new one, just in case. If you don't have new ones, you can pull another fuse from another non-essential circuit (i.e.: power windows if it's the same amps) to test out. I'm curious why they'd put in cigarette lighter blanks?
Anyways, I've heard that car chargers will blow fuses. Not sure why that would be but some owners unplug their car charger when not in use. If replacing the fuses check out, then my next guess is wiring. I've heard these had problems with that.
Also, if you have the manual, give that a look see for fuses; they've probably hidden more somewhere. That's all I can give you. I don't know much about these cars. If it was an E32 on the other hand....
Production: 02/1990
Gale's Repair Page
ETK Online
Old 06-28-2010, 12:32 AM
I am going to call the dealership this morning and ask them if they have any insight into this. Fuses were all pulled and checked and double checked, just does'nt make any sense to me! Thanks for your attempt at helping out.....
Old 06-28-2010, 04:28 PM
Okay! There is a relay between the 50 amp fuse and the 2 20 amp fuses. The relay is bad and does not allow power to the 20 amp fuses or to the outlets. Cant believe the dealership was willing to disclose that to me over the phone without a paid visit!
Old 06-28-2010, 10:27 PM
Never hurts to ask. That's good stuff, personal thanks for replying with the fix. Not many people do when they find the answers, they never disclose what they found.
As for the dealership, I've found that they will give you lots of info if you call in and ask, especially if it's something small like a relay.
Production: 02/1990
Gale's Repair Page
ETK Online
Old 07-05-2010, 03:55 PM
Bad news! Replaced the relay and that did not cure the problem. the outlets only work when they feel like it. sometimes they are on, and sometimes they are off. Seems to relate to the ignition switch. The dealership is going to take a peek at it on Thursday and see if they can figure it out.
Old 07-06-2010, 06:37 PM
Well, I know on the E38's the ignition switch can cause a bunch of problems due to wear. I think the E65's have that fob slot in the dash...maybe a connection isn't closing properly all the time and not closing the relay, hence why the ciggy lighters aren't working all the time.
Production: 02/1990
Gale's Repair Page
ETK Online
Old 07-14-2010, 03:09 PM
3100 3100 is offline
Banned
there is power module that is not giving positive voltage to the coil of the relay so problem is the relay is never being energized to create magnetic field and to switch controlled circuit (12V from 50A fuse to 20A fuse). My suggestion is that you remove the relay that you just replaced and you will see terminals marked as 4,8,6,5 and 2, then with the test light or DVOM check that you are getting 12V at the terminal 6 of the relay, if you see 12 V use jumper wire to bridge 6 with 5. it should work now. Please post back results. Good luck - al Once you jump this two terminals do not install relay
Old 09-11-2010, 08:38 AM
sologuy10 sologuy10 is offline
Originally Posted by lincolnmaster80 View Post
Never hurts to ask. That's good stuff,BMW personal thanks for replying with the fix. Not many Car people do when they find the answers, they never disclose what they found.
car photos
