Old 06-26-2010, 08:29 AM
ellis479 ellis479 is offline
Cool 2003 Buick Ultra EVAP system code
Hello,
I am getting a check engine light on my 2003 Buick Ultra 3.8 super charged engine. Checked with my innova 3100 OBD 11 and it shows a code PO440 EVAP system. I have checked the gas cap and the hose running from the power booster. What else should I check to fix this problem? Thanks ellis479
Old 06-26-2010, 10:44 PM
HotZ28's Avatar
HotZ28 HotZ28 is offline
AF Moderator Elite
Re: 2003 Buick Ultra EVAP system code
You should check all the vacuum lines & fittings going to and from the charcoal canister, as well as, those from the manifold to the purge solenoid. Pay particular attention to the elbow connections.
Old 06-27-2010, 02:37 PM
hinton08 hinton08 is offline
Firefighter317
The only way to truly find an EVAP leak is to take it and have it smoke tested at a repair shop. You wont be able to see if the gas cap isn't sealing more than likely. I'd get a gas cap from the parts dept at the local dealership, probably for about $20 or so. You can try getting a gas cap at Auto Zone or something but on the newer vehicles, I've seen aftermarket gas caps not fix the problems, and then get a GM gas cap and it fixes it. So i'd just fork over the extra $10-15 to get a AC Delco gas cap and not risk it. More than likely that will fix it. If for some reason it doesnt, I would take it to a dealer to have it smoke tested to pinpoint the leak. Hope that helps
Old 06-27-2010, 10:07 PM
HotZ28's Avatar
AF Moderator Elite
The OP says:
One question remains, how was the the gas cap checked?
Old 06-28-2010, 09:34 AM
Cool Re: 2003 Buick Ultra EVAP system code
Hello,
I replaced the gas cap as advised, since I could not see any cracking on the rubber lines. I reset the service engine light with my OBD tool and so far the light is staying off. Thanks for you help Hot Z28 and hinton08!!! ellis479
Old 06-28-2010, 05:02 PM
Firefighter317
Probably meant that they checked to make sure the gas cap was tight
