Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 06-26-2010, 01:39 AM
camarogolfguy's Avatar
camarogolfguy camarogolfguy is offline
Send a message via AIM to camarogolfguy
08 Power Door Lock question
My 08 driver's side door lock will not go up or down using the key fob or the door mechanism. It tries to go up and down, but can't make it either way. It works manually by hand or with the key in the door. I tried some W-d 40 in the lock but with no luck. Any ideas?
Old 06-26-2010, 08:31 AM
j cAT j cAT is offline
Re: 08 Power Door Lock question
remove the interior door panel and operate tthe lock see if it is binding on something ...use white litium grease on the linkages and areas where it slides..
Old 06-27-2010, 10:36 PM
Thanks. I will give that a try.
Old 07-04-2010, 08:18 PM
Pats1999 Pats1999 is offline
Local Chevrolet dealer is replacing door lock actuators right and left.. My neighbor had all 4 of his replaced last week (after two had already gone bad).. Our LTZ with only 11K miles on it, the driver rear door isn't not unlocking good enough for the handle to work..
It appears to be a known issue.. Same problem we had on our 1999 Suburban!!
Gotta get that fixed, and our hood won't stay open anymore...
2003 Bonneville SSEi
2008 Suburban LTZ
Old 07-05-2010, 07:47 AM
Firehawk97 Firehawk97 is offline
Its the door lock actuator assembly. They are junk on the new body style C and K trucks. I have replaced many of them and have done a few truck with all four.
Old 07-05-2010, 11:33 AM
thanks for your report on this .
