99 GT axel seal leak
I have a 99 Grand Prix GT CP 69K I replaced the LF (driver side) axel. Axel seal now leaks bad. I used air gun on spindel nut real tight..
I took it apart axel came right out not hooked on snap ring. Replaced seal it looked fine with new one.. Made sure axel was seated right, and tightened with air gun again. First time took a month to leak this time 5 days. Have since found out torque setting by GM is 159.. Could the torque setting be causing my problem by taking all slack and give away. Putting tension at the snap ring and first good bump pops it loose enough to slide out enough to let the seal leak? Or could it be a defective axel? |
Re: 99 GT axel seal leak
Are you referring to the drive shaft seal at the transaxle or hub? On torque is this the axle nut?
I talked to my cousin today it was his air gun and he said it only goes to 110-115 lbs torque on his compressor which I used... He checked it several times before.. I also checked the box the axle came in it is the correct axle and it called for 118 lbs of torque.. At this point I'm thinking it's the axle that's defective.. But I really would like someones opinion that knows more about this than me, before I tear it apart for the third time.. |
If you used his air gun to install the axel nut you could have damaged the wheel bearing. You should only use a ratchet and a torque wrench when removing and installing axel nuts.
Are you sure you didn't damage the axel seal when you pried it out of the trans? You could replace the seal and axel both one more time, but if it leaks again, you may have damage a bearing on the final drive section of the trans.
-2000 Grand Prix GTP 170,000mi (daily driver) -2000 Olds Alero 100,000mi (soon to be DD with gas at $3.45/gal) -1997 Chev K1500 4x4 115,000mi (Natalie's truck [nans_grandprix]) AF "2.0" Community Guidelines Conservative Victory 2012!!! "I'll Keep my Guns, Freedom, and Money. You can Keep the Change!" ----->>>>> Did You Know? <<<<<----- |
Where did you get your aftermarket axle? Where are you getting the seals? Over/under torquing the axle nut will have no effect on the seal leaking. I've seen plenty of those cheap aftermarket axle causing leaks try a different brand and get a GM axle seal.
I bought the axel from Auto Zone.. I think it is defective.. I plan to take it back and get another one or my money and try Advance... |
Did you ever get this problem resolved? I'm having a very similar issue...
If you have a leak at the axle seal, was any work recently done?
If no, then the seal is leaking and just needs replacement.....have never seen grooving in axle shafts that could cause a seal to leak......have only seen that happen on harmonic balancer shafts, that can cause a new front cover seal to leak.... It appears, the previous problem was caused by an axle sharft that had not only rotational movement, but also in and out movement due to a worn retaining clip.... |
