Go Back   Automotive Forums Car Chat > Chevrolet > Monte Carlo
Old 06-25-2010, 07:56 PM
nycemsmedic67 nycemsmedic67 is offline
coolant leak...
how do i remove and what is the part name of the elbow hose on the passiner side of the motor,that runns from the lower intake , under a type of sensor to a brakett by the tensoner pully directly above the water pump to the heater core inlet? its pissing out of the bottom due to a crack in this plastic pipe. at first i thought it was the water pump, but i actually saw it dripping onto the manafold. its really bad where on a 5 mile trip i over heat, and loose all coolant. its a 3.8 chevy z34. ty Dave
Old 06-26-2010, 03:46 PM
Re: coolant leak...
just real quick, this pipe ......to install it do i need to remove the intake manafolds? the pipe has a 90 deg. bend and both holes are aligned with each other. thanks
